No real issue with going to 110 m if it keeps it to a single loop per zone - also helps where you have changes in emissivity of the floor surface to try and retain these within a single loop (ie carpet vs tiles) so would be worth checking if you can get Bed2 onto a single zone. Would also allow running just the bathrooms in the spring/autumn if needed.
Ok, thanks for that. Makes sense.
So it's worth checking back with the supplier of the plan as to why zones are created or split? Assuming that if you could merge split zone in bed 2 for example that this would also then mean you can reduce the size of the manifolds?
thanks again.
