Hi
Hoping someone can help.
Our fitted dishwasher has leaked at the back into the supporting board underneath. Subsequently the dishwasher leg has sunk and we can't free the machine to repair.
Any ideas how we can release the sunken leg and shift the board?
Thank you.
Try pushing at the bottom and pulling at the top (at the same time) to tip it forwards and lift the leg/wheel out of the hole its made? If it will tip forward like that perhaps you can push a 3mm metal plate under the machine for the rear leg to slide run on? Lots of hands needed.
Chock it up, and then wind the legs up as per above. Almost every single DW I’ve ever fitted has the screw at the front to raise / lower the leg/s at the the rear.
RTM ( Read the manual ) or google the fitting instructions for details. ?.
Replace the wooden board with cement board / other. Why the ‘support’? Timber floor?
