KM4344 Posted May 26, 2020 Posted May 26, 2020 Hi guys a have a difficult one (or maybe not) I have some wood panels with a an upright support at the front. I need to tighten the panels from the rear to the support but l dont have any access from the rear. Any ideas on how i can go about this? Any special fixings that work with this type of arrangement. Thanks in advance....
Vijay Posted May 26, 2020 Posted May 26, 2020 If I understood right, maybe spring toggle fixings would work
Temp Posted May 26, 2020 Posted May 26, 2020 (edited) There are several variations on this theme.. Glue a "block" of wood to the front side of the panel next to the upright. When dry pull on the block to pull the panel to the upright. Then screw or bolt through the block to the upright. Cut off any excess block. You can also put glue between the panel and upright before pulling on the block. Or.. Drill holes in the panel. Tie a rope to the middle of a bolt to make a T shape. Push bolt through hole and jiggle it until you can't pull it back through. Use rope to pull panel to the support while glue dries. When dry use narrow nose pliers or similar to turn bolt so it can be withdrawn through hole or just cut rope and let bolt drop behind panel. Fill hole with plug. Or Drill holes either side of upright. Pass semi rigid wire or cable tie through one hole and guide it to the other. Grab with pliers and pull it through so both ends now on your side. Glue as above. Pull wire and tighten around support. Edited May 26, 2020 by Temp
dpmiller Posted May 26, 2020 Posted May 26, 2020 https://www.screwfix.com/p/hafele-keku-fixings-m4-x-48mm-10-pack/8663t
Roundtuit Posted May 26, 2020 Posted May 26, 2020 I assume simply screwing from the front through the support is out of the question? What's behind it? Can it be assembled flat and then put in place?
