carlosdeanos Posted May 19, 2020 Posted May 19, 2020 I am just doing the demolition of my patio so I can dig the foundations. I am having a concrete slab floor. I have been saving all the stones and what I think is the previous hardcore. However I am finding a lot of half bricks, paving slabs etc. Can I chuck this all in the hardcore pile? Thanks.
ToughButterCup Posted May 19, 2020 Posted May 19, 2020 16 minutes ago, carlosdeanos said: ... Can I chuck this all in the hardcore pile? Yes. But, I (if I can be bothered) separate big bits out: they serve well quickly to fill this, that and the other. 1
carlosdeanos Posted May 19, 2020 Author Posted May 19, 2020 @AnonymousBosch thanks. You take the big chunks out and don't include them in the new hardcore? Would you break up large slabs?
Onoff Posted May 19, 2020 Posted May 19, 2020 (edited) I sieved a load of my old floor through a 40mm mesh. If a bit was too big I smashed it up smaller and stuck back through the sieve. Bricks, tiles, Celcon, flints, mugs I broke whilst building so SWMBO didn't see it... Then half bags of off cement, plaster, whatever to get rid of it. Edited May 19, 2020 by Onoff
carlosdeanos Posted May 19, 2020 Author Posted May 19, 2020 @Onoff fantastic - exactly what I needed. I will smash it up a bit. It wont cause issues with the floor will it? Like its not going to sink!
Onoff Posted May 19, 2020 Posted May 19, 2020 14 minutes ago, carlosdeanos said: @Onoff fantastic - exactly what I needed. I will smash it up a bit. It wont cause issues with the floor will it? Like its not going to sink! Should be fine. Note I compacted mine with a whacker plate. I was basically too tight to pay out for MOT Type 2. 1
carlosdeanos Posted May 19, 2020 Author Posted May 19, 2020 @Onoff Thank you. Yes I figured I can save a couple bags worth as well, so that's great.
Bitpipe Posted May 19, 2020 Posted May 19, 2020 The base of my basement excavation was lined with 150mm deep of 'type 1' - in excess of 20m2. After it was laid and compacted I had a look and managed to fill a wheelbarrow with taps, pipes, wood, cable and other miscellaneous 'stuff' and that was just from the surface. Looks like they just got a load of fresh crush from a local yard - i'd swear the there were probably bits of the original house that was pulled down a few weeks previously in it. 1
