BuildStore, Ecology or other?
From reading the forum, the general consensus seems to be that BuildStore service isn’t the best but they seem to offer the cheapest interest rates but combined with the highest upfront fees. Ecology seem to get really positive reviews for service, slightly higher interest rates but with less up front fees and basically, no else seems to get a mention.
Do these two have the market pretty much cornered or are there any other alternatives that people would be happy to recommend?
An indication of an achievable interest rate for, say a 95% land and build borrowing deal, and what type of up front fees I can reasonably expect to pay would be really helpful.
Thanks all in advance
Loads of fees.
I had an initial chat with them and had to run and get a piece of paper.
What part of the UK are you planning to self build in?
I'm in Scotland and the options available for us were limited.
8 hours ago, Thedreamer said:
Loads of fees.
Presume you are talking about BuildStore there?
I am in England, Lancashire to be precise
 Yes.
Remember they are a broker so different products might have different fees. The one they mentioned for me was the Newcastle building society.
In the end I went direct to the Scottish building society.
If you are in England you will have a lot more choice.
My advice to you would be to research different building societies and see what you can get directly. Some will only deal through a broker other can provide one direct to you.
When you have a few interest rates and fees etc compare back to buildstore and see where you stand.
As per @Thedreamer said it depends where in the country you are, what also can affect it is the construction type and finish.
I am in Scotland also and currently about to choose buildstore or ecology direct for a formal application, but I have been procrastinating around doing the cost vs benefit on them both as its lockdown and I've got lazy.
However for an insight from my quoted prelim prices for buildstore see image below:
Ignore the £9625.
The arrangement fees may slightly vary but if you choose the advance type arrangement they will all be payable (but may vary) if it is arrears  then the indemnity fee disappears. This is all however subject to where you are and specific to your build hence best to discuss with them..
My experience so far....buildstore....slow awkward and full of hassle. Ecology
..pretty easy to deal with but dont know.of they can bring the cheaper deal to the table. Everything else.you have read I would concur with that I have read the same.
@Thedreamer I did lookat SBS but they seemed to have this really high 5 odd % rate and that was higher tha the rest so had discounted them. How are you rating the experience?
Ignore the £9625.
Thanks, that illustration is helpful
What interest rate were you quoted by Ecology vs BuildStore and was in on an advance or arrears product?
I presume they scale similar to normal mortgages, ie the less % you borrow against the land/build cost then the better the interest rate is?
@SuperJohnG
They were quite difficult to get the mortgage from. Took a year and lots of emails.
The other option was a self build loan scheme from Scottish Gov but the last time I checked was 9% if you go outwith the agreed position.
The interest rate is higher for SBB, but I'm fortunate that I have been able to use other financial resources to reduce the drawn downs needed until the end of the build.
I paid a single arrangement fee of £1200, £250 + VAT for a valuation at the start and £50 for two further valuations. From a quick calculation my interest charges have been around £2,500.
All in I would expect the self build finance cost for interest and charges/fees to be between £4,500-5,000. I don't have another mortgage/rent commitment and therefore each month I hold off moving in I either reduce the mortgage or up the spec. With my second drawndown just before the lockdown I'm still saving a bit of money but it would be better to finish.
Once I have completed the self build (which should have been last month!) I will automatically drop down onto their standard residential rate.
  • 3 months later...
We went with Ecology. At the time felt like the buildstores fees were far higher than Ecology.
Glad we went with Ecology as very easy to contact (always get the same case manager) and very quickly arrange things for you. I expected going for a self build mortgage was going to be pretty drawn out but it went through within a month or two.
  • 5 months later...
for ecology do you not need to spend more on the build though? do they not want it to be very high spec insulation etc?
You need to have a plan to be SAP B rated or better (https://www.ecology.co.uk/mortgages/c-change-discounts/#sustainable) to qualify.
Your final as completed energy / performance rating determines the actual discount applied, but you're likely to move back onto a standard lender once the build is complete and you've exited their min term.
