DaveH Posted April 26, 2020 Share Posted April 26, 2020 (edited) My first floor is block and beam with a habitable ground floor area below it containing kitchen and living space. What do I need to consider when running services between the floors - MVHR ducting, cables, pipes etc? I was thinking of casting some ducts into the floor in the appropriate areas (mainly above the utility/plant room) to run all the services through. Is this the norm? Obviously I will keep hot and cold pipes apart, electricity and data cables apart. I assume i will need some kind of intumescent seal in case of fire? Anything else to consider? Thanks Edited April 26, 2020 by DaveH Link to comment Share on other sites More sharing options...
Russell griffiths Posted April 26, 2020 Share Posted April 26, 2020 You don’t need to cast anything in place. If it is block n beam just core drill the holes as and when you need them, up until the point you screed upstairs you will be able to see the beams so easy to just drill where you need the services instead of trying to get it right and being a bit off, you will probably find screening upstairs will be a long way down the list of jobs so lots of time to get services in the right place. Link to comment Share on other sites More sharing options...
nod Posted April 26, 2020 Share Posted April 26, 2020 All services can go on the underside of the first floor and hand a ceiling under them afterwards Fixing access panels on the ceiling to get at any valves etc Link to comment Share on other sites More sharing options...
DaveH Posted April 28, 2020 Author Share Posted April 28, 2020 Thanks, there will definitely be a service void between the beams and the ceiling below but I was more wondering about the detail where things like cables will pass through. It will be easier for me to group rings and lighting circuits together and then pass them through the block in a group in a conduit/duct of some kind. And pipes for water supply, underfloor heating etc - should I sleeve them where they pass through the block? Link to comment Share on other sites More sharing options...
Russell griffiths Posted April 29, 2020 Share Posted April 29, 2020 Yes you would sleeve for protection, but not cast in place, drill holes as and when needed your floor designer should be made aware of any large penetrations so they can move the beams left or right as you obviously cannot drill through a beam. Link to comment Share on other sites More sharing options...
