Sandybay Posted March 24, 2020 Share Posted March 24, 2020 Hi, Just finishing off my Nissen Hut, have sink with cold water, was wondering if it would be possible to have a solar thermal system providing hot water when possible for washing hands etc, Is this possible, what sort of storage tank / system, would be required? Thanks Link to comment Share on other sites More sharing options...
Ferdinand Posted March 24, 2020 Share Posted March 24, 2020 (edited) I would think you could either roll your own, or buy something off the shelf designed for a boat or caravan. But I would expect that solar PV would be less buggeration-ful over time. Ferdinand Edited March 24, 2020 by Ferdinand Link to comment Share on other sites More sharing options...
SteamyTea Posted March 24, 2020 Share Posted March 24, 2020 PV is the easier and probably cheaper option. Could even charge a battery and run your lights off it. Link to comment Share on other sites More sharing options...
jamieled Posted March 24, 2020 Share Posted March 24, 2020 There are 12v immersion heaters you can use with small p.v. setups. Haven't tried it myself. Link to comment Share on other sites More sharing options...
Sandybay Posted March 25, 2020 Author Share Posted March 25, 2020 Thanks for the replies, will look at a 12 volt immersion,and solar pv system. Link to comment Share on other sites More sharing options...
SteamyTea Posted March 26, 2020 Share Posted March 26, 2020 10 hours ago, Sandybay said: Thanks for the replies, will look at a 12 volt immersion,and solar pv system. Cheaper to use regular modules and a cheap inverter. Less Volts, More Amps, Bigger Switches. Link to comment Share on other sites More sharing options...
