scottishjohn Posted March 13, 2020 Posted March 13, 2020 (edited) anyone looked at this looks like its better than insulated raft- or is it me Edited March 13, 2020 by scottishjohn
ToughButterCup Posted March 14, 2020 Posted March 14, 2020 Schaumglas, German innit? No bloody wonder it's expensive.
Jeremy Harris Posted March 14, 2020 Posted March 14, 2020 Unless you have a special need to use the higher compressive strength version of foam glass (for example as a thermal break if using strip foundations) then I can't see any real benefit. It's far more expensive than EPS and has a slightly poorer λ in it's least dense form. The one advantage it has is that it's available in a high enough compressive strength form to be used to take quite high loads, but the snag is that the high compressive strength version has a higher λ too, around 0.05 W/m.K.
scottishjohn Posted March 14, 2020 Author Posted March 14, 2020 was thinking of the foam glass chips --not the sheet have messaged them and will see what they come back with -not seen any prices yet I suspect that my house will be built on solid rock -so may be that will already be better than mud etc should be dryier -- so maybe do not need that thick a layer
Jeremy Harris Posted March 14, 2020 Posted March 14, 2020 3 minutes ago, scottishjohn said: was thinking of the foam glass chips --not the sheet have messaged them and will see what they come back with -not seen any prices yet I suspect that my house will be built on solid rock -so may be that will already be better than mud etc should be dryier -- so maybe do not need that thick a layer The thickness only depends on the insulation level you're looking for, really. Our slab has 300mm of EPS underneath it to get the U value down to around 0.1 W/m².K, and if we'd used foam glass we'd have needed a similar thickness, but it would have been a lot more expensive. 1
scottishjohn Posted March 14, 2020 Author Posted March 14, 2020 2 minutes ago, Jeremy Harris said: The thickness only depends on the insulation level you're looking for, really. Our slab has 300mm of EPS underneath it to get the U value down to around 0.1 W/m².K, and if we'd used foam glass we'd have needed a similar thickness, but it would have been a lot more expensive. the calculator they put on site --says different -which is why I,m waitng to speak to a real person -it say about 0.04 with compacted foam glass shards we will see
Jeremy Harris Posted March 14, 2020 Posted March 14, 2020 7 minutes ago, scottishjohn said: the calculator they put on site --says different -which is why I,m waitng to speak to a real person -it say about 0.04 with compacted foam glass shards we will see The laws of physics dictate the thickness needed for a given U value, and the λ of foam glass is given on their website, so it's very easy to work out. The high compressive strength stuff has a λ of 0.05 W/m.K, the lower compressive strength stuff has a λ of 0.036 W/m.K Ignoring perimeter losses and the λ of the concrete slab itself, to get a U value of, say, 0.15 W/m².K the thickness needed would be about 235mm. To get the U value down to a lower value, say 0.1 W/m².K would need a thickness of about 350mm (the actual U value will depend on the area/perimeter ratio, edge losses, slab thickness etc, so this is just a rough and ready estimate). A layer of compacted glass shards 0.04m thick, if we assume the λ is around 0.04 W/m.K (which is probably optimistic), will give a U value of roughly 0.85 W/m².K, which is way over the limiting fabric values in building regs, which give a U value of 0.25 W/m².K
