Pocster Posted February 28, 2020 Posted February 28, 2020 So , I’ve got this for bathroom and ensuite walls . First question - is there a side that faces in I.e tiled on ? - or does it not matter ?? Seems quite flimsy (12mn I think ) . Whilst I’m sure it does the job is it better or advised to marine ply the walls then attached the delta board ???
nod Posted February 28, 2020 Posted February 28, 2020 Delta fine no need for ply unless you are hanging something heavy Hardly anyone uses marine now Writing facing out 1
Pocster Posted February 28, 2020 Author Posted February 28, 2020 (edited) 7 minutes ago, nod said: Delta fine no need for ply unless you are hanging something heavy Hardly anyone uses marine now Writing facing out Cheers ! Does it compress ? What I mean is if I hang a heavy wall unit ( it’s fixing go straight into stud ) - the unit is against tiles and delta underneath - will the delta warp / bend ? Edited February 28, 2020 by pocster
Mike Posted February 28, 2020 Posted February 28, 2020 Since the board apparently has a BBA Agrément Certificate, that should have the details. I'm currently looking for a similar product so just tried looking it up and can't find one, and the link from their own web site is dead (at the foot of this page) which is curious... 1
MikeGrahamT21 Posted February 28, 2020 Posted February 28, 2020 Marmox Multiboard is very similar to this stuff, and very good 1
nod Posted February 28, 2020 Posted February 28, 2020 1 hour ago, pocster said: Cheers ! Does it compress ? What I mean is if I hang a heavy wall unit ( it’s fixing go straight into stud ) - the unit is against tiles and delta underneath - will the delta warp / bend ? I would put a timber patress behind where you intend to hang anything Though Delta is pretty robust 1
