Adam2 Posted February 18, 2020 Share Posted February 18, 2020 Looking at levels for a new driveway that will finish at the garage entrance and thinking that if we want to improve the very rough surface of the garage what are our options (size is ~7 x 5.5m). 1 - sand/grind a bit and tile = ~25/35mm increase in height 2 - as above but a latex compound instead of tiles 3 - as above but an epoxy compound instead of tiles 4 - thin layer of concrete maybe with fibres It's kind of important right now as this will determine the level we want to finish our driveway at and this (as per other post) is beam + block + concrete so the structure beneath that can be adjusted but when built will be staying as-is aside from the final surface which probably is resin but tbc. Not sure how good options 2 & 3 are for wear and how thin you can go with option 4 so info appreciated Link to comment Share on other sites More sharing options...
PeterW Posted February 18, 2020 Share Posted February 18, 2020 Up to 15mm then use something like a Weber Pro leveling compound - they are final wear surface and can be laid 3-15mm thick 2 Link to comment Share on other sites More sharing options...
Carrerahill Posted February 18, 2020 Share Posted February 18, 2020 (edited) 39 minutes ago, Adam2 said: Looking at levels for a new driveway that will finish at the garage entrance and thinking that if we want to improve the very rough surface of the garage what are our options (size is ~7 x 5.5m). 1 - sand/grind a bit and tile = ~25/35mm increase in height 2 - as above but a latex compound instead of tiles 3 - as above but an epoxy compound instead of tiles 4 - thin layer of concrete maybe with fibres It's kind of important right now as this will determine the level we want to finish our driveway at and this (as per other post) is beam + block + concrete so the structure beneath that can be adjusted but when built will be staying as-is aside from the final surface which probably is resin but tbc. Not sure how good options 2 & 3 are for wear and how thin you can go with option 4 so info appreciated As I saw it (I was nearly in a similar situation as you at one point) I either diamond ground it, or I put on a heavy enough layer of levelling compound and designed for vehicular use (including things like trolley jacks etc.). This was weeks, maybe months of plotting and planning and what I came up with based on pricing things and all sorts. Luckily the problem disappeared for me as we ended up building a new garage! Edited February 18, 2020 by Carrerahill 1 Link to comment Share on other sites More sharing options...
AliG Posted February 18, 2020 Share Posted February 18, 2020 We used the leveling compound which from memory was the cheapest solution. A fox then walked through it during the night putting some paw prints in it! 1 Link to comment Share on other sites More sharing options...
