Wow, that seems expensive - £60 a tub!  I was planning on using Bamboo Flooring Company as we love the look of the wood and it seems much harder than oak so can be used in kitchens.  But I had not budgeted for the adhesives. Looks like I may need to revise our budget.
2 hours ago, PeterW said:
Yep - used this one
http://www.bambooflooringcompany.com/ever-build-lumberjack-650-adhesive-14kg.html (used for bamboo)
and this one
http://www.bambooflooringcompany.com/sika-bond-ms-wood-floor-adhesive-14kg.html (used for oak)
Both work really well  and you get around 20sqm per tub.
Certainly aware of Sika, but when you start looking, there is a fairly large choice of products available, for roundabout the same sort of money, that all claim to do the same job.
Goes a long way !! 20sqm is £3 a sqm. That's not much difference to a decent tile adhesive
I used the sika for the same setup and have had no problems two years down the line. Think I only paid £30 a tub though. It's seriously sticky stuff, you only have maybe at a push 1 min to get the board into place and make sure it's good other wise you will need a spade to get it off the concrete.
