Underground drainage Y junction
nickw
Does anyone know if I can get a y junction that is different to the normal offset 2 pipes into one, I'm trying to source 1 y junction that is shaped more of a u shape so 2 x 110mm inlets into 1x 110mm outlet but with the pipes parallel and not set at the normal angles.
I have seen them before on the web but I don't think they were UK.
Shape wise like this https://www.ebay.com/itm/2-5-Inlet-Dual-3-5-Out-Twin-Exhaust-Tip-With-One-Clamp-Stainless-Steel-/173766186547
You can get that exact "U" thing as I have seen it in my merchants, I would download the Osma and Marley and FloPlast catalogues and have a look. I had a look through an MK catalogue the other day and found all the bits I needed after being told "No, no one does anything like that".
