Patrick Posted December 7, 2019 Posted December 7, 2019 I have a pile of paving bricks and wondered if they could be used for a Garden wall. Would make it double skin with the inner wall being paving bricks and the outer (outside facing) wall being reclaimed victorian red brick. I have them around from dismantling the old building but not enough to do the entire wall with them. Any disadvantages using pavings bricks? any problems?
Onoff Posted December 7, 2019 Posted December 7, 2019 I'd say no. The blocks have no frog so the resultant wall won't be very strong.
Patrick Posted December 7, 2019 Author Posted December 7, 2019 (edited) OK. Understand. Only that the reclaimed red bricks from the old house got none either So you would say in both of them, mortar don't stick too well? Edited December 7, 2019 by Patrick
Mr Punter Posted December 7, 2019 Posted December 7, 2019 I think these would be fine for a garden wall. Give them a proper clean and encourage whoever is laying them to choose the best side. Use a lime mortar. 1
Gone West Posted December 7, 2019 Posted December 7, 2019 26 minutes ago, Patrick said: OK. Understand. Only that the reclaimed red bricks from the old house got none either The bricks from the chimney breast in the bungalow I dismantled didn't have frogs and they lasted ninety odd years and the chap who took them on Freegle used them for a garden wall. 1
Patrick Posted December 7, 2019 Author Posted December 7, 2019 @Mr Punter What's the advantage over cement mortar? I'm comfortable mixing that but never used lime.
Onoff Posted December 7, 2019 Posted December 7, 2019 Lots of theories as to the why of frogs: https://www.scottishbrickhistory.co.uk/brick-frog-origins-of-use/ 1
Mr Punter Posted December 8, 2019 Posted December 8, 2019 20 hours ago, Patrick said: @Mr Punter What's the advantage over cement mortar? I'm comfortable mixing that but never used lime. Softer - the mortar should be softer than the brick - more environmentally friendly, better colour / weathers better, traditional / heritage, possibility of reusing bricks. Makes the mix workable. You could use 1:2:9 cement:lime:sand. 1
