Hi All,
What do you use (or recommend) to use in a UFH / Radiator system with regards to inhibitors and Biocides.
We previously had Fernox F1 in the Radiator system, but now that its a combined UFH / Radiator system should I use something else?
Thanks, Wozza.
I was on the phone yesterday to Fernox confirming compatibility of their various products in our UFH (no radiator) system.  The chap I spoke to recommended (assuming your satisfied that antifreeze levels are sufficient), dose with F1 inhibitor and F7 biocide.  Why not phone their technical team direct?
I have emailed Fernox Tech. - Just got the reply which says only to use F1 Inhibitor in a combined UFH / Radiator system as the higher temps will kill off any bacteria.
  • 3 years later...
I am puzzling over biocides for my central heating system.
My system will be UFH and a ASHP, brand-new plastic pipes and with no radiators.
Its a low temperature-system and so might be prone to bacterial growth and biofilm formation.
But on the other hand, tap water contains chlorine.
Reading the Vaillant manual for my UniTower (an all-in-one UVC) it says: "Do not use any unsuitable antifreeze and corrosion inhibitors, biocides or sealants". And then does not list any biocides on its approved list.
So should a biocide be added to an UFH system or not I wonder? What have others done?
