deano85 Posted November 2, 2019 Share Posted November 2, 2019 (edited) Evening all. Im Dean... Unlike most in here, im not looking to try anything too big. I work a fair bit so other than general decorating, i tend to get tradesman in for jobs and piece if mind... I do however have a little project im looking to take on myself over the winter, so am looking for a little advice I have a old outbuilding with a shuttered concrete roof, inside are 2 walls in a 'T' shape making a shed at 1 end and a smal toilet and coal shed at the other end... Ive allways wanted a big shed/workshop So... What are the chances of removing said walls? They are not tied into the outside walls, but the outside walls are only 1 brick thick. Theres a lentil that goes from 1 side to the other above the 2 doors which will remain This sort of work would not be hard for me if possible Any advice would be great Cheers Edited November 2, 2019 by deano85 Link to comment Share on other sites More sharing options...
joe90 Posted November 2, 2019 Share Posted November 2, 2019 Good on you for having a go, I did a job on a similar extension and it was like a bomb proof building, burnt out two Kango hammers demolishing a wall, (luckily I rented them) not saying yours will be that hard but be careful ?. If the lintel spans the building it should be ok but at the moment it is supported between the doors so not taking the whole weight. Might be a good idea to get a builder in “to give you a quote” and see what he says about it!. Link to comment Share on other sites More sharing options...
ProDave Posted November 2, 2019 Share Posted November 2, 2019 +1 to getting a professional to have a look. You are probably okay as the roof is probably strong enough but all the internal walls would need to go right up to the ceiling. Link to comment Share on other sites More sharing options...
newhome Posted November 3, 2019 Share Posted November 3, 2019 Check that there is no asbestos in there before you go smashing anything up. Link to comment Share on other sites More sharing options...
deano85 Posted November 3, 2019 Author Share Posted November 3, 2019 Its all just brick and concrete thankfully 1 Link to comment Share on other sites More sharing options...
