I need to do an air test on one leg of my UFH as the timber frame installer decided to drill in a doorway when fitting the internal wall soleplate. The question is will an air test work to find if there is a leak now the pipe has been encased in concrete for over 12 months or will it be better to do a wet test to see if a wet patch develops? Hope this is not to silly a question!
I would (temporarily) undo the screw he has inserted. Any leak then (air or water) will be obvious.
If no leak put the screw back.
That is my reasoning also but I also want to test all the legs and just wondered what people thought about using air rather than water
