colin7777 Posted August 21, 2019 Posted August 21, 2019 Hi, Couldn't find an exact forum area to put this so sorry if in the wrong area. Does anyone know how to export DWG or DXF file from Drawing Express, I don't have the package but my Architect doesn't know how to do this but has said he will send me the file if I can explain how it is done. Thanks Colin
Temp Posted August 21, 2019 Posted August 21, 2019 Google says they have a good telephone support line. I guess this doesn't work?... file -> save as -> then use drop down menu to change the file extension to .dxf or .dwg
SteamyTea Posted August 22, 2019 Posted August 22, 2019 (edited) 9 hours ago, Temp said: file -> save as -> then use drop down menu to change the file extension to .dxf or .dwg It may be under File-->Export-->[pick your format from list] Quick look at their website and it says that it can only export as PNG, SVG and DE https://drawexpress.com/faq.html Edited August 22, 2019 by SteamyTea
Ed Davies Posted August 22, 2019 Posted August 22, 2019 https://cloudconvert.com/svg-to-dxf Don't know how much extra information DE will put in the SVG and how much of that will be picked up by cloudconvert but it could be a possible route to at least get basic 2D geometry converted across. SVG won't do 3D.
colin7777 Posted August 22, 2019 Author Posted August 22, 2019 (edited) 1 hour ago, SteamyTea said: It may be under File-->Export-->[pick your format from list] Quick look at their website and it says that it can only export as PNG, SVG and DE https://drawexpress.com/faq.html Hi, this is a different package, it is Drawing Express ‘ by Trial Systems' in the UK. I don't have the package, it is my architect who uses the package but he doesn't know how to find the facility. It uses a tablet and pen so I guess it is selected somehow from the various areas on the tablet rather than selecting File etc from the screen. . Colin Edited August 22, 2019 by colin7777
Jeremy Harris Posted August 22, 2019 Posted August 22, 2019 The web site for Drawing Express says that it is .dwg/.dxf compatible: http://www.trial-systems.co.uk/products/drawing_express/ That means there should be an option to either "save as" .dwg/.dxf of perhaps "export" as .dwg/.dxf. I'd expect these options to be in the "file" menu somewhere.
Brian-H Posted December 18, 2019 Posted December 18, 2019 I use the drawing express package myself, (Mine is up to date version 2022), Down on the right hand side, tablet ref 29-30/2 the is a save as ACAD/DXF, simply save the file then send it any way you wish
PW1 Posted March 15, 2023 Posted March 15, 2023 Hi I have some old Drawing Express .exp files I need to convert to .dwg. I don’t have access to the software anymore. Can anyone convert them if I email / Dropbox them?
SteamyTea Posted March 15, 2023 Posted March 15, 2023 (edited) 9 minutes ago, PW1 said: Hi I have some old Drawing Express .exp files I need to convert to .dwg. Post up a small file and we can all try out out CAD programmes and see if one works. Try Windows 3D viewer, says it opens *.exp Edited March 15, 2023 by SteamyTea
