bBooth Posted August 13, 2019 Share Posted August 13, 2019 Hi, Buying a timber frame new build house, which is finished internally, awaiting k rend to be applied externally and a detached garage to be built, I was surprised to see mains water gas and electric only just being connected as how would anything in the house been tested, central heating ran, leaks spotted on pipe work etc, is this normal on new build to only get connected at this stage and do they use alternative supply for testing before plastering and painting? Cheers Link to comment Share on other sites More sharing options...
ProDave Posted August 13, 2019 Share Posted August 13, 2019 Pipework can be pressure tested without a mains connection and all electrical dead testing can be done and even a certain amount of live testing with a generator. I would not say it is normal to leave services until this late, but there must be some reason why they did that. Link to comment Share on other sites More sharing options...
nod Posted August 13, 2019 Share Posted August 13, 2019 19 minutes ago, bBooth said: Hi, Buying a timber frame new build house, which is finished internally, awaiting k rend to be applied externally and a detached garage to be built, I was surprised to see mains water gas and electric only just being connected as how would anything in the house been tested, central heating ran, leaks spotted on pipe work etc, is this normal on new build to only get connected at this stage and do they use alternative supply for testing before plastering and painting? Cheers Quite normal We had no water on so we manually pumped the pipes full of water and left full of water with a pressure gauge in place The UFH we filled with air 1 Link to comment Share on other sites More sharing options...
bBooth Posted August 16, 2019 Author Share Posted August 16, 2019 Thanks for your replies, good to know that it’s normal Link to comment Share on other sites More sharing options...
