willbish Posted July 27, 2019 Posted July 27, 2019 Has anyone got any experience with SolFit in roof panel system? British firm, partnered with Bisol panels, where the backing mount is factory fitted. Installation looks straight forward. Not quite as competitive as equivalent 300W panel and GSE mounting, but not far off. BisolSolfit270-300Wp.pdf
eandg Posted January 21, 2021 Posted January 21, 2021 Bumping this thread as looking at this as an option now. Will, did you go with them?
willbish Posted January 21, 2021 Author Posted January 21, 2021 1 hour ago, eandg said: Bumping this thread as looking at this as an option now. Will, did you go with them? Nope I went GSE with 19x Jinko 305w panels.
eandg Posted January 21, 2021 Posted January 21, 2021 (edited) 21 minutes ago, willbish said: Nope I went GSE with 19x Jinko 305w panels. Thanks, any particular reason for your choice? Edited January 21, 2021 by eandg
willbish Posted January 21, 2021 Author Posted January 21, 2021 Price and availability of install information. I felt well prepared to DIY after reading everything written about GSE on Buildhub.
eandg Posted January 21, 2021 Posted January 21, 2021 38 minutes ago, willbish said: Price and availability of install information. I felt well prepared to DIY after reading everything written about GSE on Buildhub. Will have a search - cheers. Did you go direct or through a merchant?
willbish Posted January 22, 2021 Author Posted January 22, 2021 Friend of a friend runs a solar install company. I went to him with the best price I could find which was solar-energy-store.co.uk and he was able to knock a chunk off. 1
Alexphd1 Posted January 22, 2021 Posted January 22, 2021 https://midsummerwholesale.co.uk/buy/roof-integrated-solar-pv Thats a decent price to kick off with then shop around. We used GSE in roof on 1st build but planning to use easyroof system as it integrates very nicely with velux windows.
eandg Posted January 22, 2021 Posted January 22, 2021 8 hours ago, Alexphd1 said: https://midsummerwholesale.co.uk/buy/roof-integrated-solar-pv Thats a decent price to kick off with then shop around. We used GSE in roof on 1st build but planning to use easyroof system as it integrates very nicely with velux windows. Thanks. Will do some looking around and get quotes. I read the GSE system integrates with Fakro flashing which might be interesting.
Sandybay Posted January 22, 2021 Posted January 22, 2021 What kind of price would you expect to pay for a complete 3.6kw system, could anyone recommend a place to get a price from, would it be a diy fit to a bungalow roof, are they best fitted before slate goes on?
willbish Posted January 22, 2021 Author Posted January 22, 2021 (edited) 1 hour ago, Sandybay said: would it be a diy fit to a bungalow roof It certainly can be. Jobs include fixing extra battens, mounting trays, routing DC cables, fixing flashings and getting the panels on the roof (definitely a two person job!) 1 hour ago, Sandybay said: are they best fitted before slate goes on? Depends where on the roof you are putting the panels. If you are putting them at the eaves/gutter you can start straight away with the trays before any slates. If positioning them mid way up the roof then the bottom flashing goes over the slates so in my opinion it's easier for slates first up to the line of the trays. Lateral positioning is also important so you don't end up with a sliver of slate at the side flashings. I posted some detailed photos on Instagram, which shows how I did a mixture of slates then trays then the last slates and finally the panels. Although appreciate that if you are working with contractors this is probably not possible unless they like coming and going alot. https://www.instagram.com/p/B9q63EUnlmQ/?igshid=mhyygq9ysf1u Edited January 22, 2021 by willbish
Sandybay Posted January 23, 2021 Posted January 23, 2021 Thanks willbish Will check out your pics later?
Sandybay Posted January 24, 2021 Posted January 24, 2021 Checked out your pics willbish, nice work, I can see the benefits of the tray system, will look really nice with finished slate on. ?
