All shifting towards SBD as standard, basically boils down to security. Laminated outer pane on ground floor windows. That must resist a physical attack by an opportunist/casual burglar.
Doors and windows must be manufactured to a design that has been tested and shown to meet the security requirements of British Standards publication PAS 24 (equivalent EN standard RC2 is acceptable).
PAS24 is published by the BSI. PAS 24 provides a method for testing and assessing doors and windows in relation to security.
All ground floor and accessible doors must have suitable laminated glass with a security value of P2A or better. Windows do not require laminate glass for PAS24 but must have a locking handle.
Edited by craig
Hi @craig
confused as normal, in your answer you say
Expand
However you also say
Expand
So are there two lots of regs we need to look at. Should I clarify with bc.
Cheers russ.
It’s the same thing, all ground floor windows with laminated glass. Pas24 tells you the laminated glass should be P2A lamination or better.
Hi @craig
Doing a lot of reading, and still not as clear cut as I would like
so let’s say I have a window that is in a downstairs room, bottom of window is 600mm from floor, this would require TOUGHENED GLASS for inner pane, and LAMINATED GLASS for outer pane.
Is this correct???
That would be my understanding. Toughened inner for safety reasons, laminated outer for safety and security.
Anything below 800mm will need to be toughened/laminated. Anything within 300mm of a external door will need to be toughened/laminated.
  • 5 years later...
Expand
Hi Craig,
Sorry for the reply 5 years after you wrote this. My inspector just refused a set of RC2 doors, where did you find out that they should accept RC2 as I cannot find anything on this? many thanks
  On 24/09/2024 at 13:41, mattgibbs said:
Hi Craig,
Expand
All I can say is, every BCO is different and how the interpretation of the standards is undertaken. I would say have a look at the topic here for further assistance, but as a side note, RC2 and RC3 are acceptable for entrance doors, supply the documentation and evidence available is paramount.
