I have started laying my first course of inner wall blocks at a level which requires wall ties. For some reason I keep forgetting ties and have to knock a block off to rectify.
Can anyone recommend a fool proof reminder method for wall ties?
I am now thinking of stacking the blocks dry with a wall tie sandwiched according to a wall tie plan, then as I lift a block off the stack the tie will fall, then surely I won't forget.
4 minutes ago, PeterW said:
Are you using profiles ..??
Hang them on the string pins above the row you need them in.
I like that and completely idiot proof i.e. have the wall-tie dangling from a second higher profile line such that it will obstruct the laying of the block where it should go.
I hope you are not poking them in after you have laid the blocks ??
if you lay a bed down approx 1.5m to 2m then push the ties down into the bed, you basically don’t pick up a block unless you have picked up the ties
its just a 3 stage process
bed
ties
block.
Keep a bucket of ties right next to you
you will be tripping over it so much you will never forget them.
