Mr Punter Posted July 1, 2019 Posted July 1, 2019 Unroll over the blocks with the "inside" facing up.
epsilonGreedy Posted July 1, 2019 Author Posted July 1, 2019 14 minutes ago, PeterW said: ..?? Roll I’ve got in my hand has same both sides... Mine 100mm wide from Capital DPC has a diagonal grid pattern embossed from the other side (inside of the roll).
epsilonGreedy Posted July 1, 2019 Author Posted July 1, 2019 26 minutes ago, Mr Punter said: Unroll over the blocks with the "inside" facing up. I like that idea and hope the dpc manufacturer anticipated such a workflow with the ridgy face ending up on the right side. Thinking back to the age of 5 when I watched a house being built I recall dpc was made from a material like tarry roofing felt which had better inherent surface friction hence no concerns about "slip planes".
Brickie Posted July 1, 2019 Posted July 1, 2019 1 hour ago, epsilonGreedy said: Thinking back to the age of 5 when I watched a house being built I recall dpc was made from a material like tarry roofing felt which had better inherent surface friction hence no concerns about "slip planes" ... though it does give an unsightly bulge as it’s compressed out by the creep of the building. 1
PeterW Posted July 1, 2019 Posted July 1, 2019 5 hours ago, epsilonGreedy said: Mine 100mm wide from Capital DPC has a diagonal grid pattern embossed from the other side (inside of the roll). Odd.... Visqueen is embossed both sides ....
