Rob99 Posted June 21, 2019 Posted June 21, 2019 We obtained full planning for our front extension, which is now complete, but are finding that the new front door position on the face of the extension is a bit exposed. Previously the front door was recessed back from the front house wall by about 1.2m and I'm thinking about adding a small porch. Would this new porch be classed as PD (as porches would be normally) or does the new extension change things somewhat and I'd need planning permission (which I suspect they'd refuse) ?
bassanclan Posted June 22, 2019 Posted June 22, 2019 PD applies to the original house. You would need planning, unless you were putting the porch on the front of the original house (e.g if the front extension made an L shape)
Temp Posted June 23, 2019 Posted June 23, 2019 (edited) Class A (Extensions) apply to the original house but I don't see that condition in class D Porches.. http://www.legislation.gov.uk/uksi/2015/596/schedule/2/part/1/crossheading/class-d-porches/made Quote Class D – porches Permitted development D. The erection or construction of a porch outside any external door of a dwellinghouse. Development not permitted D.1 Development is not permitted by Class D if—(a)permission to use the dwellinghouse as a dwellinghouse has been granted only by virtue of Class M, N, P or Q of Part 3 of this Schedule (changes of use);(b)the ground area (measured externally) of the structure would exceed 3 square metres;(c)any part of the structure would be more than 3 metres above ground level; or(d)any part of the structure would be within 2 metres of any boundary of the curtilage of the dwellinghouse with a highway. Edited June 23, 2019 by Temp 1
Rob99 Posted June 25, 2019 Author Posted June 25, 2019 Thanks Seems quite clear that it falls under PD. I've also checked the original PP and there are no conditions which would disallow a porch. ?
