Dutch
Personal Information
  • Location
    Pendine, Wales
Dutch's Achievements
Member
Member (3/5)
0
  1. I am considering purchasing the VENT AXIA SENTINEL KINETIC PLUS B It has been suggested pre insulated ductwork is the way forward. The unit has 4 spigot of 150mm distribution box size 150mm All the pre insulated ductwork I can find is 160mm so it would need reducers into the Unit x4 2 x Distribution box Then I would need about 6 metres of. Insulated duct 11 elbow, from the what I can see I would need connectors between the pipe and elbows, so far this process is ridiculously expensive £500 are the any cheapest supplier, tried bpc, ventilation land, epic air
  2. He not done any calculations on the Nudura. I have emailed Nudura so hopefully they will help.
  3. What size of rebar is needed ? how many per block ?
  4. I am having issues finding the correct quantity of rebar to use and the size, structural engineer just said it a system he is not familiar with.
  5. https://www.justdoorsuk.com
  6. I have heard about this before, normally the seller has tried and failed to get planning, if you are successful later on they want 50% so if you paid 100k for the land then achieve planning and its valued at 200k you have to pay the seller 50k 50% overage clause
  7. Self Build Zone I found was cheaper, for me it shaved 2k off https://www.selfbuildzone.com/structural-warranty
  8. Your post is not very clear, yes the same brand will normally install onto the board. mcb are miniature circuit breakers 6amp 20amp 32amp etc rcd residual current device rcd in a board will normally have 4 or 5 mcb you normally have two RCD in a populated board. rcbo - Residual Current Breaker with Over-Current this allows each circuit to have RCD protection without turning the other circuits off. so if your lights have a fault and trip they won’t turn off your freezer etc. I hope that helps. please let the sparks do the install & mods.
  9. Can you put all the insulation externally say 300mm, 2 sheets of 150mm cellotex ? So inside you just run the power cables under the plasterboard, plaster the ceiling.
  10. Welcome, I am just buying a plot in Carmarthenshire so not a million miles away.
  11. House is a new build so nothing there existing.
  12. Toilet on 1st floor redesigned, redesigned ensuite 1st floor, swapped kitchen and diner around.
  13. I am considering adding a door to the kitchen from the top of the stairs, but this will compromise the kitchen. Any other comments appreciated.
  14. I have made the garage longer & shorter, swapped the master bedroom with the kitchen diner, made the rear bedrooms wider. Garage is 6m x 4m
