SBMS
7958 profile views
SBMS's Achievements
Advanced Member
Advanced Member (5/5)
238
  1. My hydraulic design in case it’s useful. 100% possible. Find a certified Panasonic installer and your installer would do as mine did and defer to Panasonic technical to do the design. They just install. If it’s wrong it’s on Panasonic so as long as they follow the schematic they are covered.
  2. as JohnMo said with the hydraulic design pretty much but I wanted true cooling so I went fancoils so I can run at proper ac temperatures. I’ve installed this exact setup with a Panasonic aquarea tcap heat pump. Ground floor is UFH and first (and second floors) are 7x fancoils. All pipework lagged and all fancoils have condensate drains. It took a while to get the design how I wanted it and warrantied with Panasonic. I had an extra towel rail loop that they wanted to make sure was isolated from chilled water so that’s why I couldn’t go off their standard design. I can run 5 degree water in cooling mode to the fancoils and keep the UFH loop at above dew point (16 degree) as the Panasonic accepts a dual zone temperature control. It’s critical that the heat pump controller actually supports this and Panasonic was one of the few that I found that was big, reputable and would warrant the hydraulic design. I worked with their technical design team to get the design right. it fundamentally works by having two circuits off the buffer (sorry but yes, Panasonic mandate a buffer for hydraulic separation in this system design). In cooling mode, heat pump can chill the buffer to 5 degrees. That loop is pumped straight to any FCUs that demand cooling. The second loop to the UFH has an inline temperature sensor and a 3 way mixing valve. The temperature sensor connects back to the heat pump controller and that makes sure that water leaving to that circuit is blended up with return water to a safe minimum temperature. If the circuit stabilises at say 16 degrees the zone valve closes to prevent the circuit going any colder. it’s a pretty simple setup really. I had additional complexity because the towel radiators are on the same circuit as UFH. There’s a zone valve I installed before this circuit that is controlled by loxone relay so in summer I just deactivate this. You could Do this with a heating controller as well (or a switch!).
  3. We’ve gone fancoils upstairs and UFH downstairs. Dual zone setup on Ashp so we can run the fancoils with proper chilled water in hot temperatures. Hoping we will be in in next few months and will report back in summer if it works!!
  4. You absolutely should be.
  5. Not in yet!! Will let you know when in
  6. You can use cavity closers there are ones keyed to accept wet plaster https://www.coversmerchants.co.uk/dacatie-tf-multicloser-cavity-closer-100-150-x-2400mm
  7. FCU per room much simpler. Have DMd you the contact. But this was through an installer…
  8. Panasonic will also do a heat loss calculation as part of their design so they can size the correct unit
  9. Hi lizzie ive just gone through this process with Panasonic and our installer. I wanted the setup you are aiming for - UFH as zone 1 and fancoils upstairs on zone two. Everything I have read on the system points me to it being well designed and totally capable for what I want. The weak link was indeed Panasonic uk design. Eventually I got the contact details of the design team themselves and liaised directly with them. I don’t think many people in the uk use the two zone setup so it took a while to get the design so we all understood it. The benefit is that they produce the full hydraulic and electrical design (not that straightforward) AND then warranty it. So if anything is incorrect Panasonic pick up the tab. Your installer just follows it. the rep was useless and just tried to sell me aircon. The best thing to do is strongly suggest that the design team follow Panasonics own reference diagram which you can find in their main manual. Can forward if you need. The Panasonic control unit is fairly smart and supports multi zone by way of controlling a mechanical blending valve and water temperature sensor. In cooling mode this is what protects your UFH from running too cold. Return water is blended to mix up to a limiting temperature (say 16 degrees). Fancoils can run at 7 or 8 degrees which is what the buffer will be chilled to. You can even do the reverse in winter and have your zones on different temps if you want the fancoils running a bit hotter ( probably not necessary). All my pipework was lagged. In theory it should be as good as aircon. PM me if you want the email For the guy I spoke to at Panasonic. It’s a very capable well designed system though and only one I came across that natively controlled multiple zones, had the fcus from same manufacturer etc. and the tcap range is very impressive in the way it can maintain a constant output irrespective of environment temperature.
  10. This was my reasoning. And I have loxoned everything to death so can automate the immersion (a timer would probably have sufficed like JohnMo said - but does mean I can integrate PV production to top up when it’s generating most). To respond re eco credentials - it’s a balancing act right? Building a house isn’t an eco statement for me. But where I can I have tried to minimise heat loss with good quality triple glazing, 200mm cavity, airtightness (meaning I need MVHr) etc. Then the home automation and using ASHP for cooling is for comfort and because I like the hobby of tinkering with software and programming. I guess it’s more eco friendly to only have one unit to save resources on building, shipping etc, but wasn’t primary motivator. the ultimate eco statement is not to build a new house at all probably and buy existing stock - but then most of us wouldn’t be here would we?
  11. True but that’s a fraction of runtime really - and can be scheduled in the early hours (when it’s cheap). Personally I think simplicity is having one system doing both, but maybe it’s my OCD not wanting a unit sitting there unused half the year.
  12. I considered whether to install AC or not but have decided to fit fancoils to the first floor bedrooms and landing areas and have a two zone ASHP system. So can cool to proper AC levels in summer if needed. Wasn’t hugely more than a standard ASHP and was roughly the same as not doing UFH upstairs. And installed MVHR as well.
  13. I looked at these but they were quite a bit more money than GSE I think
  14. Yes although going to be tough to do this with only 250mm or so to the verge..
