richo106
Everything posted by richo106
  1. Sorry for the terrible video, but this is sound around the buffer tank that is not normal
  2. Normal temperature
  3. The UFH is off so house not hot and I have checked everywhere and seen no obvious sign off escape of water
  4. It’s like it’s tried to do it’s sterilisation but not managed to get upto temperature and just continuously ran
  5. I am going to answer these to the best of my knowledge 🙈😂 The immersion heater for the hot water is fed from the ASHP, I think there is just an immersion heater in the dhw it sounded like the noise was from around the buffer tank but the ufh was turned off on the controller
  6. Hi I have an ASHP that has 100L buffer tank and 300L DHW tank, I finally had my hot water commissioned couple of weeks ago. I have turned the UFH off left the hot water on and it has kept ticking over the last couple of weeks and has been fine (used hardly any electricity as not been living there) Yesterday when I was at the house it sounded like water was ‘cycling/flushing’ just within the plant room where all my tanks are which I hadn’t heard before and it was doing constantly and when I checked the energy monitor it has used 100kwh in 24 hours!! I turned the Ashp controller off and it stopped, I had the plumber over today and he turned it back on and it wouldn’t do the same thing but I am concious this will most likely happen again I know this is a very vague issue but has any body got any idea what this could be? literally any ideas/ suggestions will be very much appreciated many thanks
  7. Thanks again for all the comments The issue with the underlay we have gone for the heat flow under flow which is only 6.1mm thick. I might do a mixture of both, belt sander it and then filler if needed
  8. Hi All Another random issue if anybody could offer some advice. Where my 22mm T&G floorboards change direction there is slight lip and as this is on the middle of the landing where it is going to be carpeted I am concerned that you will feel it under foot and eventually show through the carpet What would be the best way just to take the lip off it slope it on so it wouldn’t be so noticeable? I completely forgot about this and have now started painting so any ideas that wouldn’t be ridiculously dusty would be preferable…not sure if there is any! Many Thanks
  9. Thank you @Bozza The hunt begins for the right coloured silicone 😅
  10. Good Afternoon I am finally getting round to decorating and I am really unsure on how to finish up to my built in kitchen tall units I have attached a couple of pictures to show you what i mean, the issue is there a small gap all the way round from my units to the wall. It varys from 1mm to 3mm in different places I can't imagine I can just leave the gap, do I try and put a straight bit of frog tape and then caulk, remove tape when wet. Then paint but I am guessing at that Any ideas or suggestions would be very welcome!
  11. Hi @Tumble Since insulating all the pipework and turning the system on I have had no condensation issues
  12. Thanks all for the comments, very helpful as always! I think I may stick with the post method as I have done 90% of the work and filled in my sheet as I have gone along What are the expected time scales of the refund? Many Thanks
  13. Hi All I will be looking to submit my VAT reclaim (for a conversion - property empty over 10 years) around the end of May I started this 2 years ago and have all my invoices numbered and in a folder - they will all need photocopying anyway as they don't return the paperwork. I have now seen it can be done online now and by post, what is best way to do it? What are the timescales like for receiving the money back in your bank? Many Thanks
  14. Hi All I have painted mdf skirtings downstairs on top of tiles Would people recommend a clear sealant all the way round from the bottom of the skirting to the tiled floor? If so what is the best clear silicone to use? Kind Regards
  15. Hi All We are only a few weeks away from moving into our home and the mrs has decided she might want a burglar alarm now - even though we have a full CCTV system The internals of the house is 95% complete so would have to be a wireless system Could anyone recommend a good wireless burglar system at all? Many Thanks
  16. Hi We are having issues with phone signal within our house and it's very frustrating when making calls, me and the mrs are on different networks and its the same for both I have tried looking back through the forum and its look like people have used chinese mobile phone boosters Could anyone recommend one that would be suitable to boost signal for all networks maybe? Only issue now is my house all almost finished so I can't run any cables internally unfortunately
  17. Hi @gambo Due to some awkward positioning of internal steel beams I had to run the majority of my downstairs ducting down a bedroom wall which I then studded off. Not ideal but this was the only way i could make it work The cowls I have are: https://masltd.com/product/helios-roof-terminal/ These were installed by my roofer (at least 1.5m apart and horizontally) and then I ducted to them I questioned the supplier of the system and they were not concerned about mould/condensation, I only turned the system on last week so will just have to see how it goes
  18. Thanks @JohnMo Really appreciate the reply, I will fully insulate it tomorrow before I get the system commissioned.
  19. The MVHR is fully installed, it’s just the loft insulation that is only half done Do you mean wait until fully insulated too? We are not living there currently
  20. I have installed my MVHR and is going to be fully commissioned on Tuesday The couple of days I’ve found quite of bit of condensation coming out 2/3 of the outlets. I am guessing this is because majority of the pipes and vents are not properly insulated in the loft and the heating is on low. when the system is fully commissioned and turned on Tuesday will this stop all condensation built up even though the ducts are fully insulated yet? it’s making wet patches on the ceiling and conscious it will ruin the paint when I do it. many Thanks
  21. Thanks for all the replies Mainly due to costs I think I am going to take a punt with the Aruba switch and AP's Many Thanks
