markharro
1 Follower
markharro's Achievements
Regular Member
Regular Member (4/5)
61
  1. We dont yet have our outlet plumbed in to the drain but rather it is dropping into a bucket below the MVHR unit and empty the bucket as and when needed. Because of this its easy to monitor the water coming out - the confusing thing is that the bucket has been dry for about the last 6 months! Is this normal over the warmer months? thanks
  2. Ah this is first floor so timber but good tip for someone else. Not too fussed about liquid damage as its in an obscure spot and may not even be used.,
  3. Do you just use standard metal back boxes for these? Thanks
  4. Ah of course I see the point now - I guess I will need to check I can make the hole large enough to pull the driver through but still be able to screw the detector base onto the PB!
  5. I am about to plasterboard the ceiling and need to work out how I can make the driver accessible from below in case it fails. From memory I think our electrician had allowed for it to be placed close to where the wiring for our smoke detector will come through the ceiling.......but now I dont understand this logic because the hole for the wiring will not be large enough in diameter to pull through a driver down the line......so I am puzzled about what he was getting on about. I think in another room he mentioned putting the driver near a downlight - that I can see more sense with as the downlight can be taken out and the hole diameter will be wide enough to pull the driver through. I guess with this option you would just need to take care to leave enough slack in the cabling and some way to make sure that the cable passed right above the hole for the downlight. Are there any better options? ie can you get circular plugs the diameter of a downlight that you can fit as a simple access panel?
  6. Plasterboard....what's that. Real self-builders use Fermacell! But yes I've found that the multitool is the solution for the plastic boxes....needs a steady hand and concentration! Have fitted a fair few metal boxes too!
  7. Ok great thanks - right I have decided to go for the 4 x doubles so this should be the final wiring. This look ok?
  8. thanks @Nickfromwales and others. So can I check is my amended photo showing the wiring for 3x sockets showing the wiring run correctly? I sort of need to know as intend to board over today. I may put a 4th one in but good to know if ok for 3 atm?
  9. Brilliant thanks thats good news. So does this look ok for 2x on left and 1x on right? and if I did want 2 x doubles on right as well just do the same with the wiring?
  10. Looks like our electrician has only allowed for 2x double sockets here whereas red marks on the wall were showing 2 x doubles on left and 1x on right. I suspect this is an easy fix and think I know how to do it but be grateful for some guidance. Thanks.
  11. Thanks very much @Nickfromwales v helpful
  12. Thanks everyone. @Nickfromwales when you say primer - what product do you mean specifically?
  13. I am about to tile onto Fermacell - quite large format limestone. Its not in a wet area - basically an alcove in the hall. Anything specific about tiling on Fermacell to know about that is different to using hardie cement board ? thanks
  14. Will need to bookmark this page- I have fitted a Geberit frame downstairs and thankfully managed not to balls it up! I have a Grohe frame to put in upstairs - bought it second hand so will need to hunt down the instructions online. There were really really useful videos for the Geberit frames which in no small measure allowed me as a numpty to fit it......I was hoping there would be similar for the Grohe. This has reminded me I will also need to source some extra parts eg the waste and water supply pipes will have been cut down to suit the previous install...can anyone recommend good source of spares?
  15. Any input on my post above?
