AdamD
Everything posted by AdamD
  1. Yeah tried powering it off. the thing is the 4 bars bit does change overnight but nothing happens within the unit, no water goes in and the salt is not going down. So it’s doing something but nothing everything! what is the crimp?
  2. It doesn’t look like that, but will check with a plumber!
  3. Noticed salt levels not going down and also residue on shower so had a look and it appears the softener is not regenerating properly. Everything is on, all display screen functions work etc but when regenerating nothjgn happens, usually there’s the clunking noises as it’s doing its thing but nothing now. Checked pipes and valves nothing blocked. The pic attached is on a manual regeneration cycle it ticks down but is doing absolutely nothing. Manual is as useful as a chocolate fireguard so looking for advice! Can’t contact the manufacturer yet as is weekend and Xmas so just seeing if anyone has any thoughts in the meantime
  4. Ah no it’s not that, the en suite towel rail and rad in the converted loft get nicely up to temp and hot quickly but we just dropped the ball with regard to number of rads for the size of the room. Huge error on our part really we should have insisted on one at one end and one the other for more and balanced heat. It’s cold in the coldest parts of winter and absolutely baking in summer, is what it is I guess. not putting another rad in as means ripping up the floor etc and making a complete mess of the place again. Just going to get an oil filled portable rad for the colder weeks of the winter and be done with it.
  5. Got 10 rads in the house, just looking for a way of doing it without spending my life going round the house turning a load off to just heat one room and then turning all back on again to heat the others. Basically we epically failed when doing a loft conversion by only having one rad in the new room upstairs so just looking for the best methods to heat it better without ripping the arse out of it to put another rad in!
  6. Interesting but it seems like it optimises for occupancy etc, but how does that work with a bedroom for example when you’re only there at night but could be the biggest and room in most need of heat?!
  7. I’ll be honest I don’t really know how it works but looking for advice. Have a combo boiler, standard installation. Am interested in being able to use hive or nest to be able to isolate which rooms are heated, ie. heat one in particular at a certain point of the day. - I doubt it’s even possible but a friend mentioned hive and nest and suggested it is, but I can’t see how without getting the entire system changed to a smart system. Any advice appreciated
  8. I get that but we can close off as many avenues as possible. I’ve got these to put over the air bricks, as an extra measure. https://amzn.eu/d/9sSNoRI We’re soon to rip the kitchen out for a new one so hopefully can address any other obvious access points under the plinths and behind units etc
  9. We don’t really know what it is, it’s just past the main drain from the kitchen so must be an old connection maybe for the kitchen which was in a different orientation (our old water main came in near where it is so quite possible that there was something there) or an outside toilet maybe that used to be there - no idea on that. Next door has an outdoor toilet in the equivalent place so it’s not out of the question. We can’t cap it off without excavating as it’s below a load of concrete! spoke to a builder yesterday who thinks they’re not getting in that way and if in sewer would likely have seen them from toilet bowls, which is fair but without any proper investigation I don’t think he can be certain of that.
  10. So the consensus is that capping off that broken pipe and relining the drain pipe isn’t worth it?
  11. The problem is we don’t know they are getting in that way, but we also don’t know they’re not. No other clear entry points and where the evidence was is commensurate with this bit of broken pipe. Crap like this is a shot in the dark in a way, feels like dead money but ultimately it’s a 90 year old house so dodgy clay pipe work feels sensible so it’s one of those do we risk them coming back by saving this cost or bite the bullet and say well that’s another avenue closed any ball park cost estimates?
  12. Not sure at this stage. No idea how to find out how deep it is. It’s like 18m from the manhole where we started with the cctv camera and uphill.
  13. Concrete and likely earth below that. Not sure how far, maybe 0.5-1m. It’s a clay pipe. Not sure but could be from the sewer, through the broken pipe and burrowing in. Hard to tell.
  14. Had issues with rodents recently, cctv drain survey suggests a hole in the pipe, was quite clear from the camera. The area where it is is a redundant drain pipe and we need to excavate and cap it off. What sort of cost should I have in mind for my quotes? Ball park obviously.
  15. Ha yeah so true. Hardwood chipping at 50mm depth is what they’re getting. Probably overkill but is what it is.
  16. Yeah I’m just going with 50-60mm depth. 300mm is insane. its a double swing set with small slide, hardly bungee jumping without a cord!
  17. Crikey I didn’t think I’d need that much! 370 bags for 100mm depth. That depth feel a bit ott?
  18. Created a play area for the kids at the back of the garden, swing set with slide etc. and just need to bark it to finish it off. Any suggestions as to the best type (softer the better presumably) and how to calculate the required amount? Recommended depth? The area to be covered is 44m²
  19. Best options to cover the pipes?
  20. AdamD
    Coving help
    Got this very annoying gap to finish off with coving (used to be a hatch there for the loft) and not sure how to best do it. As you can see rather than a miter cut on the front facing wall it’s straight so not as easy to meet with a bit at the wall right angle. Could do another straight bit and fill but then the whole corner would look unfinished. Also the bit to the right is not perfectly straight which doesn’t help a new piece line up very well. any ideas?
  21. Got a couple Of MK04’s which we need blackout blinds for and the velux prices are horrible! Can anyone recommend an alternative which is basically the same other than the price?!
  22. All good, got the bwt one and installed in a few hours the other day. Can tell the difference in the water softness! Fingers crossed it saves out matte black bathroom bits and helps the appliances!
  23. Does it impact the water pressure? I see they have a high flow one, does that mean better pressure within the house? Appreciate that may be a stupid question and not remotely linked!!
  24. Is this something like what you’ve got? https://www.screwfix.com/p/bwt-water-softener-14ltr/62242
  25. Thanks both, really useful. the bwt one I was looking at, screwfix right? Is it mains powered or does it not need electrical input? is the installation particularly difficult? any concerns such as the attached I’ve read online?
