sphannaby
Everything posted by sphannaby
Hi, Haven't been on here for a very long time as our renovation got completed around 8 years ago, I think I was actually more active on the old forum and everything transitioned over to here during the latter stages of our renovation. Anyway the reason I am here is I appear to have an issue with my thermal store. Typically I am working away from home so I'm remotely trying to help the wife and get a plumber sorted. Our setup is a 300L TSS store which is fed direct from a Megaflo32ERP system boiler. Only CH tied into the system is UFH which we have throughout. I have attached drawing of my store (which is exactly how it is built but drawing is missing the pocket for thermostat). Anyway the problem I have is that my boiler has lost pressure and when going to check my wife noticed water round the bottom of the store. It looks like the drain valve on the store is leaking (see pic 1) and when I asked her to try and close the drain valve a bit more she said it started to leak along the stem of the valve. So I suspect I possibly have a drain valve that will need replacing. My main question is if the valve doesn't need replacing and can be reseated so it doesn't leak do I need to check the water level in the store as I have obviously lost some water? Not sure if the store will be topped up by flow from boiler or if I will need to check the level and if so how? Many thanks for any help.
Hello again everyone, I'm starting to get back on the forum again now. Been a hectic time finishing the house off, I was forced to change job locations just as we were moving back into the house which caused all sorts of problems and we ended up living in disarray for a while! House is pretty much done now with the exception of a bit commissioning left to do and some flooring contractors to have a date in court with. With the onset of our 3 day summer rapidly approaching my better half has turned her attention to our garden. Just to give you some background I have attached some basic sketches of what I currently have and what I plan to achieve.In the 1st picture I have tried to represent the current state of our garden. The slopes are not exact but they give a fairly good idea of how it is.The 2nd picture shows our plan of how we want it when finished. The decking area is 6.5m wide and 7.5 long.I had planned on outsourcing all of the work but funds have dried up a little so I am looking to take it on myself now.The right hand side of the garden as you look at it is definitely going to be levelled off for turf to go on. Plan was to have a retaining wall at the top end and to right hand side as required, this will be built by my father in law who is a brickie.One of the issues causing me a headache is the land which the decking will go on. When we had people round to quote they said they would simple take out of the top section of the decking base area and put in in the bottom to level it out and this would mean there would be no waste from that section. I was happy enough with that but my father in law informed me that this would then create a different height step between the levelled turf area and this new decking base area. He stated this would also need to be retained somehow. When I asked the lads who quoted the job they stated pieces of 3' x 2' would be used to retain this. My father in law reckons that wouldn't be good enough and a proper retaining wall would be needed.So my next thought was to take the decking base area down level to the same level as the turfed area and build the decking up from there. This would require another retain wall but that would be around the perimeter of the area rather than hidden underneath the decking. I feel this would look neater and also allow for greater flexibility in later years should we ever decide to get rid of the decking.My main question is if I level the decking base area down the same as the rest of the garden this will give me a height difference of 500mm from base to my desired finished deck height. Is this a suitable sort of height to be able to build up to using a bearer and joist decking frame?Once I know that I can get my head round things a little better. I have done a bit research but had a few other questions hoping others can help with:1 = Am I correct in thinking I should have bearers down first and these should be attached to steel supports which are concreted into the sub base? If so does anyone have any recommendations for supports to use?2 = How would I go about calculating what size bearers and joists to use?3 = I read that decking should have a 40:1 incline ratio to prevent water pooling. Am I correct in thinking this should be achieved by putting the incline direct at the bearers rather than packing the deck boards?4 = Because the length is 7.5m I guess I will struggle to get single length of deck boards. Would I be better cutting boards to 3.75 so I have a uniform joint line down the middle or is it better to stagger the joints for more stability (for example as you would with laminate flooring)?5 = With regards to the full length steps the Mrs has stated she would like wide steps, say 2 or 3 full boards (I have done my sketch based on 2 boards). From what I have been able to find on the internet I can't seem to find any pre-made stringers that would accommodate this. Am i just looking in the wrong places or are these generally no available for wider steps (total make up height of steps will be 500mm)? Any pointers would be greatly appreciated. Cheers
Renting an anemometer
sphannaby replied to Jayobn's topic in Mechanical Ventilation with Heat Recovery (MVHR)
@Jayobn can I ask what companies you found up North that offer hire as this would suit my location? Thanks -
Very cheap MVHR
sphannaby replied to sphannaby's topic in Mechanical Ventilation with Heat Recovery (MVHR)
You can change the position of the OA and EA spigots. Its only 4 screws which hold them in place and you just swap with the corresponding blanking plate You only get to move them by 90 degrees but this may help. Its a beast of a unit and I had to move the OA to give me a decent chance of getting in at the filters. -
I will try and dig out what I have when I finish work tonight. I do have spare tiles but thats going to add in extra cost to get a tiler back and I was wanting to avoid that if possible. I have 2 doors and 1 side panel going spare, free for collection in County Durham Pretty sure the doors are of no use, hopefully it will be seen in pics I post in a bit.
Thought it best to add onto this thread rather than create a new one. We have a 900 x 900 tray and need a new enclosure. The Mrs wanted a pivot door and I couldn't manage to change her mind. Anyway it came and when our plumbers have tried to fit it the enclosure would simply not work. The only way to achieve the door being square was to have the bottom section of the door on about a 30 degree angle, similarly if you put the door section square then the actual door itself was out by about 30 degree. I had lots of to and fro with the retailer who said first of all it was a faulty door, new one was subsequently sent out and the same issues existed! After more discussion they have just agreed to give me a full refund as they state their technical team can offer no more support. I suspect that this is the first of the type of enclosure they have sold and unfortunately I have been the guinea pig as they are not even interested in picking up the 'faulty' doors. Anyway my issue now is that I must find a new enclosure. I have managed to convince the Mrs to go Bi-fold or hinged. Our problem lies that the doors we took out had wall channels that were 42mm wide and so we need something at least the same width to either take up the same holes in our newly drilled tiles or at least to be able to hide them. Does anyone know of any such enclosures that offer this? I have done much trawling of the internet and it is difficult to get the channel width on most doors pillars, then ones I can find information on generally seem to be 30mm.
We used Liberon Danish Oil and our staircase and loved the results. Really brought out the grain, definitely not orange which we were keen to avoid. Very easy to apply and I imagine you could achieve a darker shade if you wish by applying more coats but we stopped at 3 coats as it was exactly what we wanted. Just reminded me that I still have 11 doors to do when I get back home in a fortnight
Humidity controller for MVHR
Thanks. I should have looked there myself! -
Its the BPC manifolds (flat rectangular shape) that I have with the 63/75 semi rigid pipe. I was actually thinking about drilling the extract manifold box itself but now you mention it I think I have one inlet blanked off so I can just drill the plastic blanking cap and feed the sensor through there. For sensor mounting I was just going to try and get it as close to the centre of the extract manifold as possible and bond it down with duct seal or a sticky pad of some sort. -
Maybe a bit late but thought I'd chip in anyway. We looked at LED downlights and found JCC and Ansell offer decent fire rated down lights with 10 and 7 year warranties respectively. Both give out 60 degree beam angle so you don't need as many as 'normal' down lights. We went with the Ansell Orbio 360 and have been really impressed with the output of the lights and also the ease of fitting.
EDIT. Was it possibly @JSHarris who suggested using the DCH-100? -
I've just bought one of the polish DCH-100 humidity controller that were previously recommended on ebuild. I can't find the post but I seem to remember someone saying that they positioned the sensor for the controller directly into extract manifold box. From what I can see that sensor is not exactly a tiny thing so wondering how this was done? Was it just a case of drilling the manifold with a hole for the cable and feeding the cable back through then sealing cable hole with duct seal? I can't think of any other way.
Decision on thermal store or not
sphannaby replied to sphannaby's topic in Boilers & Hot Water Tanks
got that @Nickfromwales, cheers again. We got it up and running last week before I came away to work and it was running very smoothly. I did\t wire full logic as I was just using stat to control everything and using the ZV manually just to get it commissioned. I'm going to knock up a wiring diagram while I'm at work as I'm doing all my others too. I will upload a copy to see if it meets with your approval. One question I have remaining. Can you explain what the issues are with convection circulation when related to a thermal store? Bear in mind I'm a thick sparky and don't know anything about convection issues in any type of heating circuit. I understand if this si not a simple thing to explain and I may need to do some more digging myself but from my google searches I don't seem to be bringing anything up of any substance. -
Got my thermal store from Telford and they have forgot to install a pocket for the thermostat to go into! TS has to go back to be re-worked and then sent back out to me. Caused a lot of problems as I have now had to put back other trades because I can't have the plumbing ready. The joys of home building..... @Nickfromwales with regards to to your comment on using a 2 port zone valve to stop backflow from the TS to the boiler. Am I correct in thinking that the zone valve would be wired direct to a one channel programmer. Then I would have a spare set of contacts within the zone valve to give a boiler enable signal to my system boiler? Also with the 2 two port zone valve you mention to isolate the UFH. Would these be connected onto the downstairs supply and return 22mm manifold feeds or would it be one valve for the upstairs manifold supply and one for the downstairs manifold supply? ALso what would be the logic on controlling these? Hope this makes sense??? -
Sorry should have stated yes it will be gas system boiler. I thought from other discussions by using a TS it would provide enough flow/pressure to the manifold that the UFH pump that is connected to the manifold would be enough to draw through required water. What I was wanting to know was would a UVC provide sufficient flow/pressure to do the same or would i need an extra 'supply' pump at the UVC to get it to the UFH manifolds? -
Looking for advice from @Nickfromwales or some of the other experts. I had originally gone over my plans on ebuild and took the advice to go for a thermal store with a system boiler. Things have slightly changed now and I'm wondering if I need to adapt my plans based on this. My setup is as follows: 2 UFH manifolds (downstairs one is about 2 metres away from boiler/TS location, upstairs manifold is about 9 metres away from boiler/TS) House is 85m² footprint with 2 storey. I have 2 bathrooms which comprise 1 bath and 2 showers, only other DHW demand is kitchen sink and 3 hand basins. Original plan as agreed on ebuild was to have a 30-32kW system boiler which would feed a 300 litre Telford TS (also have a 50 litre expansion vessel). UFH manifolds would be tee'd into TS and there would be no need for any extra pumps as manifold pumps could handle the demand to pull the HW through. Original plan was to also have Solar PV and this would feed the immersion in the TS via iBoost (or similar). Now the idea of Solar PV is totally gone and I can't see it happening in the near future (if at all). I planned to still go for exactly the same setup just forsaking the free PV feed to the TS immersion. I was happy with this until my chosen plumber is not able to do the work so i got another guy over to go through my design and price the installation. He is telling me I am crazy going for a TS and should just have a UVC. I stated one of my reasons going for the TS was the fact I wouldn't need any extra pumps to feed the UFH manifolds and he reckons a UVC would aslo be able to do this and I would be saving a lot of money and making things a lot more simple. I got the feeling he wasn't comfortable with a TS and spun me a few lines so he could fit something he was familiar with doing. I don't think I will go with this guy anyway and I am looking for alternatives as we speak I just want some opinions on if my original setup is the best to go for still so I can be insistant on this to the other guys who I get to price it up. Any advice/ideas much appreciated. Cheers
Wall or floor, ceramic / porcelain / natural......
sphannaby replied to Nickfromwales's topic in Wall Tiles & Tiling
Nick, Thanks for those links and advice. Shower tray got set in last week and I'm very happy with the result. My tiler was also happy and stated it was a lot better than some of the work he'd seen done by a lot of plumbers (I just told him I had a good teacher ) Must say I'm really impressed with the Sikaflex. Do you also use this as a bathroom sealant for normal applications or just when needing an adhesive? -
sphannaby replied to Onoff's topic in Bathrooms, Ensuites & Wetrooms
Thanks for the share of those pictures mate, much appreciated. I had drawn up some nice plans and taken on a bit from your pics and then the Mrs dropped the bomb that she now doesn't want the bath sitting in a 'shelf' any more as it will eat up too much bathroom space. What little hair I have left is now gone! -
Haha, it could well be. Shelf for beer and Kindle is integral I was informed! Out of interest what size have you made your outside ledge of tiles that the bath will sit on? My tiles are 300*600 so presume I should do it to suit those? Possibly 150 so it is half a tile? -
@MrsRA where are you based? We are looking at something very similar and have been looking at Micro-screed/micro top and poured resin finishes. I'm up n the north east of England and we have struggled up here to get anyone who seemed half decent to do the job. We now have it narrowed down to two companies both of which I think I would be happy to give the job to. Waiting on final prices but indicative quote from both of them seemed around the £80m2. During the tendering process we have weeded out a lot of cowboys. Most could talk a hell of a game but when it came to offering guarantees or answering technical questions you found out what they were truly about. I would ask for samples from any company you are looking to get to do the work. What seem like subtle colour differences and effects can be very different from pictures shown in portfolios or on websites. Also it gives you a chance to break down the material and find out what they are using (we had one guy who claimed he was using micro topping but when we ground into his sample it was a basic sand/cement mix which had been dyed). I have some details of the main UK suppliers for Elite-crete (which seems to be a reputable brand for resin) and the guy from there was extremely helpful and said he has a list of reputable contractors for most parts of the UK. Their website is truefloorsolutions.co.uk For micro topping Ideal Work seemed to offer a good product but they only offered the product and the owner couldn't recommend any contractors in my area. If you are on Facebook you can also add yourself to a group called 'Concrete Locator - Next Generation'. Its mostly contractors based out of the USA but there are a few British guys on there. More than anything it can give you ideas of whats available and achievable design wise. A lot of the yanks have some extremely garish designs but there are some good examples of plainer designs which is what we were looking for.
Presume your access panel is on the front tapered panel? If so how would your access your taps anyway because from what I can see your taps are located on the opposite side? -
Thanks for the reply mate. Your 7 degree taper is interesting and I'm trying to get my head round it if it will 'feel' better. I just mentioned it to SWMBO and from the face she pulled she wasn't convinced! I'll just go with a standard box for mine I think (no need to complicate things if not needed). Bath on top it is for me also as the more I've thought about it the more it makes sense. The access thing is whats bothering me most. One tiler mentioned the magnet panels but he said the ones he'd done before still stand out to him and you can notice it and it draws your eye to it. The other issue I have is I'm not sure how much use an small access panel at the front would provide as my taps are at the other side next to the partition wall. The only other option for a removable place would be on the back tiles 'shelf' which the bath will be sitting on and I guess that not the best idea. Failing that I'm thinking it could be a case of tile it all up with no access and make sure I've bought plenty spare tiles. Anyone got any thoughts on other methods which could be achievable? -
Cheers Nick much appreciated. Just to clarify the battens are only needed on the 2 sides of the tray that will touch the wall? -
Thanks Nick that was a good read. My shower tray will differ from the one you shower fitted as it won't be sunken to floor level and will be sat on a riser plinth. Presume that the sikaflex method would still be the same for sealing/securing the tray? -
Just going to hijack this if thats ok. I'm looking at doing something like this (although nowhere near as complex). Our bath will just be a standard 1800 x 800 double ended bath rather than your 'spa' type bath. SWMBO has demanded we try and achieve a sunken look for the bath and I have attached a picture of something she was keen on. I'm guessing i will need wooden frame similar to what you have built to achieve this. One hing about your frame that I was unsure about is the 'shoe' design. Can I ask why did you go for this rather than a standard box design? Also I have a concern similar to you with getting access to the taps should anything go wrong in the future. I notice you have got a section with a removable tile. How do you plan to achieve make this removable? Is it by magnetic strips or something similar? Another question i had was on tile position in relation to bath top. What are the general thoughts on this is is better to have the bath top above the tile level like as shown in the attached picture or would it be better to have the tiles above the bath top level? Any pro's/con's to either method?
