Personal Information
												Location
												Carmarthenshire
Puff's Achievements
									Member (3/5)
9
	No idea what ProDave said in English but I have a Hive controlling the heating in my place but the HW bit controls the immersion heater. Not perfect but then my house used to be empty for weeks at a time and it was enough to get the HW hot for when I returned home.
	The condition was requested by some neighbours and passed by Planning Committee against advise of LPA solicitors. They could have appealed but have chosen not to. They can apply for a loft extension and that would be taken on it's merits and may be decided as over-development of the site. With the condition removed, they can just go ahead and do it and that is the worry for the neighbours, hence why the condition was requested. It may not, at the time, have passed the 6 steps though reasonableness likely to be covered. Necessity will have to be looked at obviously, though it can be argued is it necessary to have such a big house in a cul-de-sac of houses 1/2 the size or less and therefore the condition of over-development would be necessary imho
	Neighbours to a friend have an end of terrace house. There was enough space to extend the house sideways and they sought planning permission for a 2 floor side extension. This was granted but there was a condition attached that they would lose the right to Permitted Development in future with regards the roof. This was so as to NOT allow them to stick a loft extension and effectively turn what was once a 3 bed house into 7 bed house. They did not appeal. These neighbours have now completed their side extension and have now applied for a Minor Material Amendment to have that restriction removed. Can you actually change planning permission and conditions after the building works (completed according to plan) have been completed? Any other guidance on this? My thoughts are that they accepted the PP as given, built their extension and should they/future owners wish to extend upwards, there is a mechanism in place to do so, should they be successful. This is London where there are loads of loft extensions.
	Fortunately not! Last owners threw on a green box tin roof to stop the whole lot collapsing and I put in for reclaimed Welsh slate (like the converted barn next to it) and that was accepted. Bloody hate the thing, can't wait until its all gone. I've found a local farmer who'll buy the tin off me, so that's useful.
	I'm a bit ahead of you then. I was extending so had to take the end gable off first and then part of the front wall was beyond saving, so I propped up the existing tin roof and took the wall down. This allowed me dry access underneath so I could (carefully) get a digger inside to get the floor dug/levelled and new foundations. Kept the roof on in order to the floor/blockwork until high enough. Have removed 2/3 of old roof but there's still a bit over the garage, which is still being used as such. Plan is to get the other end "dry", move all the stuff over and then take the remainder down.
	Have got the rafters up for 1/2 the building but no builder for a few months, so I'm going to cover with damp proof membrane until he's back and we can do the remainder of the roof. Had considered OSB/felt the bit that's done but he said easier to get the whole roof straight without it, so membrane it is.
	Alternatively... 4.5m of 30kg/m using 1 ton winch on the tractor and braced scaffold frame but that only had to raise 2.5m
	I hired one of these to put up the steel ridge beams on my build. Longest beam was 5m and was 31kg/m so 150kg. Floor to apex is 6m and its another 1.5m to ground level at the end in the picture. I'd never driven one before but it was an absolute doddle to get them in place. Recommend using a 2-way radio if you can!
				What is the daily rate for a roof slater?
Puff replied to epsilonGreedy's topic in Roofing, Tiling & Slating
Thanks PeterW I'm fortunate in that I have a good builder to hand to show me the way. He can then do all the stuff I can't do such as stone facing whilst I'm on the roof! -
	Thanks all - found 3 large unused Velux with flashing nearby - £100 each. Don't mind one of them being in the garage
	Wow - where's the saving?! I can see some but b-me that's not cheap still. Only really after some light, doesn't need to be double glazed. I'm guessing there's not an easy way of DIY
	I'm probably been dumb here but I'm generally not too bad on google searches but... I want a sloping roof window that doesn't open. The old roof on my barn conversion was box section tin and over the garage part they had clear plastic box section, which obviously let in a reasonable amount of light. I'm keeping the garage/man cave and just re-roofing with slate (new rafters etc etc) and I essentially want to have some natural light but I sure as heck can't get up 15ft to open and it doesn't need to. All I can seem to find are normal opening velux types or flat roof windows, which as the name implies won't go on slopes.. Can someone point me in the right direction please?!
	I had 2 guys for 3.5 days doing blockwork (inc doors/windows/some steels) - £160 each/day and I was the labourer More than happy with what they achieved.
With just under 6000 to lay, think I'll be trying to do it myself as that's a chunk of budget I haven't got Long cold winter for me ahead I think! -
	As per title! I'm aware there are other options but only looking for Velux and wondering where the best (cheapest!) place to get them is? Happy to not have the latest models.
