Savage87
Savage87's Achievements
Member (3/5)
16
Semi rigid duct straight couplers
Savage87 replied to jayc89's topic in Mechanical Ventilation with Heat Recovery (MVHR)
whenever I used couplers or elbows on semi rigid ducts, they came with rubber gaskets on the inside and I used acrylic sealant and aluminum foil tape, a bit of overkill but it works. -
I'm interested in the answer as well, I have just balanced my system which was installed 4 years ago and the house is a bit leaky. I think there a bit too much ventilation TBH with current building regs. I had it set to 25-50% less and it was fine for years, boosting only when there was high humidity in the kitchen or bathroom.
MVHR Unit Suggestions
Savage87 replied to Tumble's topic in Mechanical Ventilation with Heat Recovery (MVHR)
my unit Nuaire unit has a humidity sensor on it, but it's basic. I have another humidity sensor is the bathroom which is connected to an ESP controller and it boost that way. You are overthinking it, the boost switch can be done via so many wireless options you just need to decide what would work best for you. I also boost via another ESP controller via wifi. @Ajn could you please let me know what model sensors are you using for temp, humidity and CO2? I'm currently using some DHT22's, BME280, BME680 and Xiomi BLEs -
I was considering the Domus unit to begin with and in the end I found a good deal for a Nuaire MRXBOXAB-ECO2 with a display added later on. This unit is more or less the same as the Domus one. I have gove through the same journey that you are about to go on back in 2019. If you haven't already seen it, have a look at this: Good luck, feel free to ask any questions. -
MVHR newbie.. help needed
Savage87 replied to Savage87's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Just as follow up, I had both fans replaced under warranty and also had the unit removed from the wall and hanged to the rafters as there was a considerable amount of noise to the neighbours, I could only hear it a bit in the landing at night and it didn't bother me as much. Now the unit is silent. -
In my opinion, you should have been tinkering with ideas before a major renovation. You most likely have extractor grills for the bathroom and kitchen and possibly some in line fans. Answer to your first question: chimneys need to vent at the top and bottom, not necessarily in the middle. If you success in making the house more airtight you will need to think of a solution to introduce more ventilation(with heat recovery) either decentralised or centralised. Good luck!
Condensation in the unit
Savage87 replied to Coanda's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I have a condensate trap (as a collar) on the extract pipe just above the mvhr and another hole at the bottom of the unit. Hope it helps.. -
Question about boost
you would have both extract and supply go on boost as @JohnMo said, it's a balanced system and whenever the speed of one fan increases the other one should follow so you don't get differential pressure. You could have it the just the extract boosts but there might be a disadvantages to it, not sure. -
I'm getting smoke coming in via my supply roof vent from 2 houses away. So, be very careful.
I have these fitted on my concrete tile roof, there is another model to use for slate depending on slate size. Do a search for Manthorpe Slate Vent 300 x 600mm / 500 x 250mm.
Johnny I have done exactly what you are doing, I designed and installed my own MVHR, used different parts from different suppliers and it's all OK. When you first turn it on, for a couple of day you will hear it, unless it's on it's lowest setting but you(your wife) will get used to it and ignore it. In my case I would have had the next size unit just so I can run it at a lower setting and be able to use more boost when needed. Good luck!
House is overheating
I was looking at one of those split air con units, I would have liked to fit the whole thing in the loft, but after doing a bit of research, it's a bit tricky to install it ithe loft. I'll keep on looking... Another thing that I thought about was to some how use the componets from an small old fridge/freezer to get the cooler temperature. Crazy right? -
Thanks @Dudda/@SteamyTea ! I already have bluetooth temp sensors dotted around the house and in the loft, these are connected to and ESp32(EspHome) and I do all my data logging through Home Assistant and InfuxDB/Grafana. I was hoping to find a solution to run some cool air in the supply distribution box, I'm not looking to cool the house significantly, just to lower the temperature down by a couple of degrees when the house overheats and like I said in my first post, I was looking at one of those heating/cooling coil boxes. If i wanted to heat the air I would have connected it to the boiler, but If want to cool the coil I'm not sure how to get the lower temperature. -
@tonyshouse the house in question was built in 1910 and it's a mid terrace house, I'll have to check if it got a building physics model ? Jokes. I'll have to think about putting the MVHR to sleep, it's not going to be an easy decision.. ? -
Side tracking a bit, does anyone know if you can install a split aircon unit and the outside unit to be fitted in the loft ?! ?
