Tennentslager
    6
Tennentslager last won the day on December 12 2020
Tennentslager had the most liked content!
1 Follower
Personal Information
  • Location
    Glasgow
6718 profile views
Tennentslager's Achievements
Advanced Member
Advanced Member (5/5)
512
  1. Just to finish this off. The Spacepro fittings have around 25mm of travel in the brackets, so they can slide up and down. My 10mm slope was no issue at all they slide like a half cut, suncream soaked Scotsman on Spanish flume. Job done, daughter happy
  2. B&Q Spacepro brand. MIs say 2260 is the frame height, width 3m. So my opening is 2270 at one side 2280 at the other. How do I do this? Was thinking a bit of 19mm planed timber attached to ceiling and plane it to remove the extra 10mm? Will it bend enough? Thoughts welcome... Floor is square, ceiling has been plastered after a leak and I reckon its the ceiling that's off-sloped. Plan A is to cut a timber to 2260 then mark out the gap every 150mm or so across the 3m opening
  3. Spanish mate says Inspect annually or replace Don't put behind a wally willy
  4. This is Spain. There's a sticker on each pipe but don't know what it says...everything easy to get to
  5. Hit the plus button and choose house construction- structural
  6. Is £6 for a 600x230x50mm concrete stone look okay?
  7. Does anyone @ProDave @Onoff see anything wrong with this consumer unit. Ignore the odd wire exiting, just the fuses...
  8. Got to lay 60m of coping stones on a low garden wall. I have an electric paddle mixer for plaster still in its box, also have a 65l tub. Will it work oh clever people @nod
  9. None of the perimeter drains on the plan where put in! All the extension drains are fitted underneath to the existing drains (coloured dark in the plan) So, no IC no perimeter drains at all
  10. Yes it works Yes it is vented Can't see any way to rod it Pipes are under suspended timber floor in the extension and original stuff is buried If he gets an inspection chamber fitted as per the plan (this was not done) will this be okay to rod it?
  11. Yes it works Yes it is vented Can't see any way to rod it Pipes are under suspended timber floor in the extension and original stuff is buried If he gets an inspection chamber fitted as per the plan (this was not done) will this be okay to rod it?
  12. Happy to be advised, it's all working okay but FiL worries about it, peace of mind is needed. He did suggest putting in the inspection chamber as per the plan as that did is still driveway
  13. Father in law was in hospital when builder did his extension and his wife agreed to everything he said. The plan shows new drainage around the perimeter and associated inspection and rodding points. None of this was done and everything ( shower, toilet, sink and rain water) were connected to the existing system which is now covered by the extension which is now complete. Builder was sacked long ago, there was some legal advice and think my relative kept the final payment. He is 85.
