Water
Water's Achievements
Regular Member
Regular Member (4/5)
5
  1. with octopus and they've installed a smart meter
  2. Thanks all. I'll put the completion date and see what they say..
  3. Afternoon all, I had my completion notice a few months ago and finally received a letter from the local council asking who lives in the house and when it was occupied. Well it's a little difficult to say when it was occupied and then it's when did it qualify.. After reading some tales on here I'm wondering as it isn't listed on the VOA website it won't be backdated? I don't really need another battle with the council. Any ideas?
  4. Yes I believe you are going to be looking at 4.8%+ and if the BoE rate increases as expected then it will get even more expensive. Also make sure you check out the fees. I think most(/all?) are variable rate
  5. The doors I’m looking at have a 3mm trim on the sides, not sure how easy it would be to alter the doors to fit the frames. Although the thought refitting the linings isn’t fun either. Especially as it will all have to be redecorated. Damn but there isn’t going to be a non pain in the … way.
  6. Morning all, I'm getting all new fire doors and I went to measure up the door frames and some are +/-5mm in width from the top to the bottom. I think a 5mm gap between the door and the frame is too large to look good? Also I'm pretty sure a bit gap isnt good for fire protection. I can order custom sized doors to the mm but the gap will still be 5mm + a little as the door has to open, I guess the only real option is to sand down frame argh! Not sure if I'm being too picky here?
  7. nod are you a self builder? I remember someone on here had a construction company
  8. the guidance also states "Note Please note that all invoices must be for goods that have been supplied to you. We may ask you to prove that you’ve paid for them" Sorry if I've missed your point
  9. But he wouldnt have charged you vat so you can't reclaim what hasnt been charged. If he paid for some materials in say screwfix and just had a till receipt which he gave you then maybe
  10. and if the invoice is in his name they will probably reject it.
  11. will hmrc actually repay it though? don't want my reclaim held up
  12. I have paid the net as I didn't want to hold it up. Electrician. The reason *I think* is because he paid vat on some material which obviously makes no difference as he can still reclaim.
  13. Not a lot really, I'd structure the contract differently and if I did it again it would only be once more!
  14. Hi all, Finishing a new build house and one tradesmen is unwilling at the moment to zero rate his work, it's only £14 in VAT but I feel why should I throw the money away? He was good and came out quickly but still argh! What would you do?
