BotusBuild
    11
BotusBuild last won the day on September 30
BotusBuild had the most liked content!
2 Followers
Personal Information
  • About Me
    40 years in IT, then made redundant, which has helped enormously in building. Helped with building renovations and extensions, but it was always a dream to build our own energy efficient house. Well, here we are having started (properly) in late 2020, and very proud of what we have achieved (so far!)
  • Location
    South East Cornwall
BotusBuild's Achievements
Advanced Member
Advanced Member (5/5)
689
  1. Awaits inappropriate content 🙂
  2. We now know where @Pocster's walk on glazing went
  3. We had something similar, and then we were into 2020 and all the delays that introduced !! We smile now, and there have been other hurdles thrown in our way. Things will proceed and all will be good. Stay patient, stay positive.
  4. In a non square room it took a while to decide what straight edge to start from 😀 A lot of measuring and marking to get a "centre" line, then choosing which corner should be on that line. Tips: Dry run fitting the pieces together - you may find there is one way that works better/easier for you. A centre of the room line is not necessarily the correct thing to do as you may end up with tiny pieces to fit in at the edges. Lay out 10 to 20 "rows" but only two pieces wide (hope that makes sense) to start with, then line up that "patch" of planks on your marked line, and fix it in place (glue, or several screws around the edges that you'll later take out as you add more pieces). HTH To answer some other points above, I only glued the tiny pieces at the edges so they didn't move out of place. The windows face WSW so only get late afternoon sun. Even with LVT, the angle can wander a little, but I guess not as bad as wood parquet. And yes @Super_Paulie, the struggle was real 😀
  5. Yes. It looks fecking brilliant
  6. I did that in a room about 6x8m. It nearly killed me 😁 To answer OP, no gluing, expansion gap around edges. Used trimmed tile edging to cover the gap.
  7. Duck.ai:- https://www.legislation.gov.uk/uksi/2010/2214/schedule/2 - See CLASS 6 Point 1.
  8. For internal floor space up to 30m2, no building control required in England. Don't tell my friends about my uncalibrated tape measure.
  9. Yes, you're overthinking it. As long as the ribs are supported, the bit you will be standing on will be plenty strong enough. FYI - one of ours sits on a wooden frame suitably waterproofed
  10. Good to see that things are progressing well. That DPC and insulation looks the nuts
  11. Welcome. Have fun with your build.
  12. Finished, after a few false starts.
  13. Chased in with a hot knife - I posted a video on here when I did it. Most services are in our web joist ceilings. We also have the standard 0.24 U blocks. We didn't go bonkers with AT and got a 1.8 result. I've since blocked up some major known leak points but can't be bothered with a retest. Our heating was not on much last winter.
  14. About 300mm in my case
