Lincolnshire Ian
Everything posted by Lincolnshire Ian
  1. The staircase can be adjusted to fit the gap.
  2. Hi all We have underfloor heating downstairs and want to tile the entire ground floor. Should I tile and then put in the stairs or stairs first. It makes sense to me to do the tiling first, but I have made a few school-boy errors during the build and want to sense-check. I don't need the stairs for access and, yes, I have a detailed plan for the location of the UFH pipes 🙂 Thanks everyone.
  3. I need to use pink fire rated unfortunately.
  4. Hiya I have a chicken and egg conundrum. We have a garage without doors, we want to install the doors, but the garage ceiling will need plasterboarding and plastering before we install the garage door. The garage door is on a six week delivery time. Would I be OK to plasterboard and plaster the ceiling on a garage without the door, and if I did this how long can I leave the garage without a door. Many thanks
  5. Thanks everyone. Very helpful.
  6. Hi all We have the electrician on site in a couple of days to start the first-fix. He is a super-polite guy, and I want to make his job as easy as possible. Our stud walls are up, but I don't have any plasterboard fixed (some walls are strengthened with OSB board, but not all). Do electricians usually do first-fix in stud partition walls which already have plasterboard on one side, and maybe noggins to support the back box? Or, is it normal for electricians to lay first-fix with just the partition stud-work in place? Just wondering how much humble pie I will need to eat Thanks
  7. Hi folks We are looking for composite cladding and finding it really difficult to find someone who stocks material for delivery this side of Christmas. We have spoken to Cladco - 10-12 weeks lead time for our preferred design. The same for Ecoscape and Neotimber have something which will be OK, but they don't have colour-coded screws! We aren't looking for anything funky - just an oak-type finish. Absolute nightmare. Can anyone recommend a composite cladding supplier who has stock on the shelf available for delivery. Thanks
  8. Hiya We have started designing our kitchen and have faultered at the design of the hob extractor. We have a MVHR system, but want a supplimentary hob extractor. The kitchen has a vaulted ceiling which means a "traditional" design over-hob extractor can't butt up against the ceiling for a clean design. We also aren't planning to have any wall cupboards so an extractor built into an over-hob cupboard wouldn't work either. We have looked at venting hobs but are worried that they won't have enough umphh to control the steam and are massively overpriced. Any help would be appreciated particularly with over-hob extractors which look nice "free-standing" on a wall with no cabinets or vented hobs. Thanks
  9. Thanks for your response everyone, very helpful. Its seems pretty obvious now it's been highlighted that I should use fire resistant plasterboard. I have checked my BC drawings + the build specification from the TF company and it's not mentioned. Thanks Build Hub and the super community for keeping me right.
  10. We need to finish our timber-framed, attached to the house, garage. The walls are 140mm studs with 120mm insulation which was fitted by mistake in the TF factory. We have considered plasterboard, plastering and paint, but this is quite an expensive way to finish the garage. Then we have OSB board, cheap to buy and easy to install, but with a utilitarian appearance. Are there any other options we should consider - we want it to look nice for the least possible money (who doesn't). Here is a picture of the wall. Thanks
  11. My feet are killing me! I bought a pair of cheap safety shoes, trainer style, (maybe £35-ish) from Screwfix and they are SO uncomfortable. Can anyone recommend a pair of safety boots with a wide toe which feel comfortable all day. Happy to pay what it takes for a foot-friendly safety shoe/boot. Thanks
  12. My feet are killing me! I bought a pair of cheap safely shoes, trainer style, (maybe £35-ish) from Screwfix and they are SO uncomfortable. Can anyone recommend a pair of safety boots with a wide toe which feel comfortable all day. Happy to pay what it takes for a foot-friendly safety shoe/boot. Thanks
  13. I am pushing it into a 220mm rafter leaving at least a 50mm void between the OSB sarking on the rafter and the insulation apparently the gap is important as this is a warm roof (vaulted ceiling).
  14. Hi folks I'm going to fit 150mm PIR insulation between the rafters of my vaulted ceiling. Can I simply cut the insulation slightly too large and squeeze it into the gap and the minimal expansion of the foam will hold it in place, or do I need to fix it in place. After the 150mm PIR is fitted I will be adding another 50mm PIR across the whole ceiling which will cover the rafters and 150mm PIR. Many thanks
  15. Hi everyone My clumsy scaffolders haven't been treating the breather membrane on the external face of our frame with the same reverence as the timber frame erectors and we have some minor damage. Should I repair this with "breather membrane tape", does it exist, or is there another way to repair tears? Thank you.
  16. They will want to see a drains test (already discussed it in the most and vague terms) and I'd like to test the system before needing to. If there are any problems better to know sooner rather than later.
  17. Hi everyone We would like to replicate the test that BC will want when they carry out the final inspection. I have asked them what they expect to see and the best and most detailed answer I could extract was, "a normal water test". I have bought the bung to close the pipe run furthest away from the house, and intend to fill the highest inspection chamber with water and monitor for water loss. Am I doing this right, do I need to block the soil vent pipes as with an air test , what is an "acceptable" water drop? Does anyone know of a simple guide for water testing, or could maybe answer a question above. Many thanks
  18. I spoke to the guys from Envirograf and it was a stress-free process for a novice. I explained my scenario, they asked a few questions, made some suggestions and followed up with an email - all within the space of a couple of hours.
  19. Thank you everyone - very helpful. I will call Envirograf to get the info we need.
  20. Ohh, that's a good idea. I need 32m to expand to fill a 50mm cavity. Thanks
  21. Our architect gave us the option of having vents added to the cladding or intumescent strips. We thought the vents looked pretty poor, but there might be more elegant solutions.
  22. Hi folks We need intumescent strips to close the 50mm void in our timber frame where we use cladding (about 30% of the house). I am more than a little shocked by the difference in price between cavity socks for the masonry walls and intumescent strips for the cladded walls. Does anyone have a supplier that offers intumescent strips at a reasonable price? Thanks
  23. The 2x2 is OK around the openings, but we also need cavity barriers at roof height to mitigate the potential for the cavity to act like a chimney.
  24. Hi all Our next BC inspection is when our timber frame has been erected and the cavity barriers have been installed. I had assumed that the cavity barriers would be installed as the block work went up, but apparently this isn't what the BC inspector is looking for. We have a window of opportunity between the timber frame erectors leaving and the brickie arriving to get the cavity barriers installed, but this is four weeks before the brickie arrives. I am assuming that the cavity barriers are waterproof, but will they be OK left for 4 weeks before being boxed in with the block work. Thanks everyone
  25. Nope. We are buying a timber-framed building, and the company has a number of exclusions in their service, which includes the design the outer skin of the property. We were expecting a more joined-up service due to the nature of the focus upon self-builders, but alas, that hasn't been the case. I suppose if we had read all the small print and asked more questions, it could have been clear.
