stu w
Personal Information
  • Location
    Gloucestershire
stu w's Achievements
Regular Member
Regular Member (4/5)
61
  1. I have used this method many times on builds and extensions, as have many. - Reflective thermo breather membrane (external) - 11mm OSB for racking strength and airtight substrate - 140mm timber stud - Full-fill Rockwool NyRock Frame Slab insulation - 25mm or 50mm PIR reflective thermo VCL - Service batten - Internal plasterboard Everything taped to help with air tightness. My opinion, you will always install insulation and take more care carry out the insulation and taping works yourself although it is time consuming
  2. I did 2 undercoat and 2 top coat on mine, primed any bare areas first and produced a lovely finish. You need a depth on MDF or it can show through any imperfections, do it once, do it properly i say
  3. Yes, everything gets a good coat of D4 🙂
  4. I run plywood down in my workshop and doubled up, very strong and remains nice and straight. Certainly not the cheapest method but works well
  5. I completed my own house in December 2025, using a very similar system to yours. For insulation, I selected Rockwool NyRock Frame Slab, combined with a thicker OSB layer to enhance structural performance. The majority of the building is finished with Hardie VL cladding so no external (EWI) system. I used the same construction approach on a house I built three years ago, which has performed faultlessly. Based on that experience, I chose to adopt the same system again for my own home. I stick build this project using kiln dried treated timber, at the point of the build the timber was at 12.8% to minimise movement
  6. Absolutely fine, i use a neoprene coated yoga mat from sport direct only a few pound. Pattern it dry to get a perfect fit, fix it with sticks like turbo, seal all around the edges and joints, never failed me
  7. Has the frame moved slightly compounding the issue, it might be out of plumb
  8. I line them, cures the problem, very little loss in capacity and no more condensation
  9. Fairly common with composites, the slabs bow. I have several replaced by Endurance under warranty due to faulty slabs
  10. As said, clean off if necessary with some white vinegar, then coat with patination oil
  11. I purchased all my c24 treated timbers to carry out my build a year before in required it .4x2, 6x2 8x2 and 9x2 Broke all the packs down and stick stripped every row, when build time come it was all around 12-14% and straight as a die. Not had a single bit of movement in the build. Is it practical, not really, is it time consuming yes, then having thousands of pounds of timber stored, was it worth it 100%
  12. I would say no. 30kw required
  13. Wavin Osma or polypipe hands down. Brett martin, hunter etc are cheaper alternatives, but as everything cheaper for a reason
  14. I have just gone through a similar scenario with ST water. As nickfromwales has said. Follow their guidelines, 750mm deep , sand both sides depending on the ground etc. I used barrier pipe just because I was unsure of the ground , yes it's more expensive but once it's done it's done . They were happy with a series of clear pictures of the installation. Brass stop tap on the inside and proof of insulated ducting where it come into the house
