mjc55
    2
mjc55 last won the day on August 11 2025
mjc55 had the most liked content!
1 Follower
Personal Information
  • About Me
    Bought a plot in North Dorset so that we could scratch a self-build itch that started over 30 years ago. We have been promising ourselves that we would do this for that long. Never been able to get ourselves in that position for one reason or another .
    We are in the very fortunate position of being retired, having enough capital and now owning a plot in North Dorset.
    Planning obtained! Should be able to start in the new year (2025) The plan is for a single-storey house. Flat (green) roof, Woodcrete, timber-clad and as eco as possible. Looking at passive but probably will not get certified.
  • Location
    Dorset
2601 profile views
mjc55's Achievements
Regular Member
Regular Member (4/5)
178
  1. You think that is bad! Had a slight contretemps with another car a while back, Ford want nearly £200 for a small bit of plastic to replace the wing mirror back cover. Literally a few pence of plastic and some paint.
  2. But you are not going to get a fixed price for piles I suspect! Until they start inserting piles they wont really know depths so any quote would be an estimate I suspect.
  3. Can't disagree, it might take a few years, but I suspect that it will be here before long. I'm very glad I am in my 60's, I'm not sure how the world looks for those much younger than me.
  4. How long though before houses are being built by robots? https://www.bbc.co.uk/news/videos/cgljl9zp47xo They will work 24 hours a day, to exacting standards. I would imagine that passive would be easy for them to achieve. I used to think that it was the trades that would benefit from AI as they will still have jobs whilst others won't - now I am not so sure.
  5. so what happens if you live on site while doing the building work?
  6. Just taken delivery of the Thermowood cladding for our Pod. It comes in random lengths and we have chosen two different widths that will be installed in a particular pattern. The question I have is whether we should sort the timber into similar lengths and then try and be specific in our choices of where the joins are or, after having pretty much randomised the lengths by moving them to the rear of the plot, we should just go with what we pick up (length wise). Will it be too obvious that we have tried to be random?
  7. There is no real point in continuing to discuss with you. we are at polar ends of the spectrum. You think you are right as do I. Only time will tell.
  8. Its a stretch to state that these are big con! Visual and noise impacts - visual, don't agree, noise, the juries out and location can somewhat mitigate that. Interference with radar and defence operations - really? The culling of birds - presume you are in favour of the culling of cats then? That oil jobs will go - more of a pro than a con in my opinion Fire and collapses do occur - really, didn't know that, good job oil production is harmless then! Low effective efficiency given curtailment and the inability to match supply to demand - the use of battery storage seemingly will help with this. Listen, I get that you don't like alternative forms of energy generation, but given what we have endured for many, many years from high CO2 emissions, and given it is our descendants that will suffer the most, your defence of the status quo is just beyond the pale!
  9. How is everyone doing out there? SO hot today, managed to be on site 10 until about 5:30 but it was a very, very hot one. Working inside, no way we could have been doing anything outside.
  10. Trying to decide how far to set the windows back in on our Pod build. Vertical timber cladding and I was contemplating about 80mm or so from external cladding. Not sure if there is a standard for this hence wondering what others did!
  11. Absolutely agree with @Bancroft, its the personal aspect of the planning process that has gone to pot. I changed career in 2009 and did a AT degree and after qualifying worked for myself until I retired in about 2021. I lived and worked in Wiltshire and from around 2005 - when I was renovating a couple of houses - to when I started submitting planning apps in around 2012 things had changed significantly. I used to be able to pop round to a council office in Trowbridge, chat through my plans with a planning officer and get valuable feedback when I doing the developments. By the time I was submitting plans as an AT communicating with planning officers was starting to be difficult. When I did a couple of planning applications for friends after I had retired in about 2023 the PO that visited site was a trainee, had to submit his findings to a senior planning officer (who could not be communicated with directly). For our planning application for our build in Dorset the job of communicating with the planning department was pretty much impossible. There seemed to be only one planning officer dealing with apps in our area and he just continually kicked the can down the road. It was only by complaining and going over his head did we eventually get the application approved. Something has to change, certainly the staffing issue seems to be the main area of difficulty and until this is addressed then I suspect that nothing will improve.
  12. No, house will be wet underfloor. It won't be cheap but as we are currently in rental we will be saving enough not to worry about that. Also, given that we have a lot of insulation in the Pod I'm hoping that it will not require too much heating!
  13. Had a tiler come and look at a job today. We have a 22 sq.m. pod that we are building to live in whilst we build the house. The Pod is a test bed for the house build and so the tiles we are using are 1200 x 1200 x 20 limestone as planned for the house. We had planned to tile the Pod ourselves but when the tiles arrived the other day this option rapidly disappeared when we realised how heavy they are. We are planning to use an electrical UFH mat and the tiler seemed to think that this should have a screed over before tiling! I have installed an electric UFH mat in our previous house (under slate tiles) and didn't take this approach then simply sticking the mat down and tiling over. Any views on whether this screeding idea makes sense, is the normal way to do it or are they simply making more work than is necessary? Thanks
  14. My understanding is that disabled access is required only to the principle entrance.
