tuftythesquirrel
About tuftythesquirrel
  • Birthday 01/15/1957
Personal Information
  • Location
    Narberth, Pembrokeshire
1905 profile views
tuftythesquirrel's Achievements
Member
Member (3/5)
33
  1. In addition to whatever @Nickfromwales said, I would recommend reading the CIBSE Domestic Heating Design Guide, which was significantly updated in early 2026. This document, along with CIBSE TM59 (the industry standard for assessing overheating), takes a very firm stance on the "Passive First" hierarch. I would hope they know what they are talking about, perhaps more than your builder (with all due respect). In the previous version, it said that if a client expressed a desire to fit AC that they should strongly recommend against it. In the document, the engineering guidance (aka “Ye Cannae Change the Laws of Physic”) is specifically framed to prevent a "cooling death spiral"—where we install air conditioning (AC) to solve overheating caused by poor design, which in turn uses more energy and pumps more heat into the external environment. We have a SE (18m) and a SW (22m) facing aspects and don’t need AC. If we know that it going to be 30C+ we actually keep the windows closed and use blinds to limit the solar gain. We very rarely get above 23C. So it can be done.
  2. Yes I agree absolutely beautiful, I was wondering how you will get the water to flow out of the shower and UP🙃 into the waste pipe.
  3. Agree with @Nickfromwales and decided on a 75mm radial setup. I have a friend that has installed other (series) types, as a living, but said they are a PITA, when you find that the friggin big attenuator on the design, won't fit between the joists etc. I think you would have less acoustic issues with this type of install. I got my kit from Blauberg and designed and fitted it myself. At the time (about 2 years ago) some companies would give you a basic design but things seemed to have tightened up a bit since then. None of the companies wanted to supply/extract from hallways, cloakrooms and plant room etc. so I added this as I thought it was worthwhile. In the end I couldn't see the value of paying for their design, if they weren't going to follow my requirements. I read the Blauberg manual did more research and came up with a set of design rules: Place intake on north side of building. Keep AHU away from bedrooms. Do not place valves above showers (Outside shower area) Place the Kitchen Extract Valve near the sink, not above the cooker. Kitchen, Bathroom, En-Suite and Utility Valves require a double duct run. If the duct run is greater than 15m, double the ducting. If the duct run is greater than 20m, triple the ducting. If the room is greater than 20m2, the valve requires a double duct run. Do not exceed runs of 30m. Keep the AHU flow rate as low as practicable. I did a spreadsheet with the building regulations ventilation supply and extract rates plus the additional rooms I wanted and worked back to make sure the total wasn't more than 50-60% of the AHU's capacity. The general consensus on the forum seemed to be is that you can run at a lot less than BR supply rates in practice. @Jeremy Harris has kindly put a commissioning procedure on the forum (what a guy!).
  4. @Nickfromwales Sorry about that, once I started I just sort of got hooked! Ended up doing the rest of the plant room and the open plan kitchen/diner (industrial coffee shop vibe, I am told). Fairly sure it’s back in stock now 👍
  5. I bought a Brother PT-D600 on eBay for £80 and use the free P-Touch Editor on my PC. I get the heatshrink tapes on the NineLeaf store on Aliexpress, much cheaper than in the UK. The 25mm black on white ones are less than £5 and look reasonably professional.
  6. 👍👏 Been thinking about pipes myself, ok I'm in 😁
  7. Lets face it, the standard meter box is cr*p. A couple of years and the door hinges break, the door falls off and you can't replace it without smashing the old one to bits to get it off. Then you have to cut the back off the new one to fit it around the cut out. Even more problematic if it's recessed🤐. We have the cut out and meter in plant room, in an electrical enclosure, on Unistrut. I have an 3 phase old school RCAMY meter, due to be replaced with a (smaller) SMETS2 one. Will change the meter tails and put cable idents on when the new meter gets fitted. Am I the only one that labels every cable🤔
  8. Hi, Give me a hands-on self-builder, with OCD any day 😜
  9. Same here with Welsh Water. We converted a church hall and there was some very old 1950’s ½” copper pipe coming from the main road over our property. I removed it all and replaced it with 32mm MDPE right back to where our property meets the road. Never laid a hand on their stopcock, just threw it in the skip. We need a fire suppression system (Welsh Building Regs.) so required around 100 L/min flow rate and the remainder of the ½” pipe was restricting our flow. I used the fact that we now didn’t have a stop cock to our property and asked them to provide one. They agreed and dug the road up to install the stopcock and replace the ½” copper with 25mm MDPE without a problem. Weren’t interested in inspecting it, even though it was correctly installed. Our flow rate went from 60 L/min to over 100 L/min as a result. In doing so, saved the cost of a new supply. Since they have put the water rates up this year by 27%, not losing too much sleep over it. I think it was because they have so many departments. If you speak to the developers section the official line is they need to inspect it, but the maintenance guys don’t care.
  10. Agreed for the first bit, but how are the acoustic tests carried out? You will only ever find this out when you turn yours on and every installation is unique.
  11. Hi, I've read Approved Document F and can't see where any reference is made to "an expert" or a "competent person". Appendix C provides a checklist for the commissioning engineer but there doesn't seem to suggest a competent person is mandatory. I was going to self cert. A lot of people seem to be 'DIY'ing the flow settings using the Buildhub anemometer, which made me think about how do you fill in the "Date of last UKAS calibration" column in the checklist, when using this. Has it been calibrated?
  12. Hopefully not straying too far from the main thread, the auction site John Pye usually have these. Similar style to the picture, stone resin, perfect condition, 1800x900mm, we paid £15 for ours 😁
  13. This stuff is very good.... https://www.wickes.co.uk/HG-Sticker-Remover---300ml/p/249616?gclsrc=aw.ds&&utm_source=google&utm_medium=cpc&utm_campaign=PMAX Shopping||Cleaning&gad_source=1&gclid=CjwKCAiA5Ka9BhB5EiwA1ZVtvL0anOSPITsSrlKRC3q1jYkwJaBTBGpg637GNCGWsg-lsRfP_FWcoRoCLZUQAvD_BwE
  14. Hi guys, Could any of you tell me what happens when the Loxone server fails? I've been looking at other forums where the recommendation was that the installer kept a spare one in the van!
  15. We went through this process around 2020-2021 so allow for inflation. We had quotes from 5 different architects and architectural technicians. We didn’t intend for there to be so many, however, after the initial quote, when I tried to establish some of the finer details before we appointed them, like, ”exactly where is the airtight barrier?...” “”– the realisation that they didn’t really understand my point, made us think that it was going to be difficult to get above the “we just do building regs.” threshold, rather than getting as near to passive house as possible. The prices ranged from £3k to £30k. The house is around 400 square metres. Our build cost will probably work out to be around £1000-£1200 per square metre. I can’t personally get my head around the basic concept of charging a “percentage of build cost”. Why would the architects fee triple, if our build costs were say £3000 per square metre? Our groundsmen, bricklayer, plasterer, electrician and plumber all charge by the metre or day rate, so why should the architects fee be any different? It makes no sense! The prices didn’t include the structural engineer. One of the architects said they used a specific engineer who lived 80 miles away from us. Since he charged by the hour, any site visits (even a very short one) were effectively a day out due to the traveling at £700/day. The weren’t flexible enough to use a local guy, so we would end up paying for his driving time with not much to show for it. These sort of costs can add up over time. I think the biggest reason for the variety in price, is what stage the architect is at, in their career path and their business model. The highest price we got was from a “design practice” that were a bigger outfit, with maybe a dozen people working for them. They had a scale of charges for various disciplines e.g. draftsman £55/hr. to £85/hr. for a partner. I sort of got the vibe from the quote, that any variations that were necessary after the initial design would have been charged at the specified rate (ad infinitum!). A significant portion of the fee would have been swallowed up by the practice overheads and the drawings were still in 2D. In the end, we went with a young chap that I presume, hadn’t been qualified that long. He was fully fluent in Autocad Revit (3D) and totally got the passive house “thing”. He worked from home and his price was at the lower end of the spectrum and not a lot of difference compared to the architectural technicians. Minor changes along the way were provided as part of the package. However (and probably most importantly), he was great for bouncing ideas off, which is so important at the outset. I think you need to get ensure you get value for money!
