deuce22
Everything posted by deuce22
So, a mineral wool that isn't advertised as acoustic, but is 15kg/m3, should be better than an acoustic insulation that is 10kg/m3? Somebody has contacted me from Knauf and has said that it will have 0 acoustic properties. I'll go with multiple boards then. Thanks.
Hi. Can somebody educate me on soundproofing. I have been told to use 100mm superglass acoustic insulation @ 10kgm3. I have spoke with a soundproofing company about it and they have explained that, it is primarily based on density and it doesn’t matter what the material is. So there were 2 things that I asked. 1. Would 2 standard 12.5mm plasterboards @ 23kg each give better acoustic properties than 1 acoustic board at 31.7 (as I can buy 2 standard boards for a similar price as 1 acoustic board). 2. If an insulation is not marketed as acoustic, but has a heavier weight per m3, than one advertised as acoustic, will this give better performance. He said yes to both. I’d just like to check this because when speaking with Knauf, they didn’t understand what I was asking and couldn’t answer the question. Does anybody know if this is correct? Thanks.
Thanks very much John, for your help. A 25kw boiler will be too much then, the 15kw that a friend suggested looks right. I may find another HE as it looks as if he doesn't know what to do, he hasn't mentioned any of the other things you've suggested.
Sorry, I didn't mean I contacted the plumber, I contacted the company that did the SAP calculations. Is there not a way for me to work out what boiler size I need from these monthly/yearly heat loss figures. I just want to know that the correct boiler is being installed. I know I should trust the HE, but I feel like I need to keep on top of every trade, with the eperience I've had since starting this project.
This is what I've got. I've just contacted them, but they don't know how to calculated the boiler size from the figures shown.
I have had a quick look at my SAP report. Where would I find the info I need? I'll pass some of your advice on to the HE. Thanks.
Thanks for that. I'll input the details and see what it states.
It's a heat only boiler with a 300l cylinder. Underfloor heating on the ground floor, radiators on floor 1 and 2. It's an ICF construction and my friend said straight away that 25kw was overkill. My friend said that oversizing can cause more wear and tear and will waste energy. I don't mind buying the bigger boiler, but will it just cause problems?
Hi. Is there a way I can check what the heating engineer is specifying for my boiler size. He is stating a 25kw heat only boiler, but a friend (who is also a HE, but lives a few hours away, so didn't do the work here), has said it only needs around 15kw. Thanks.
So would a heavier insulation, whether it was marketed for thermal or accoustic, have better sound proofing properties? The plasterer has just told me that he uses standard boards, but doubles them up, rather than using accoustic boards. The double standard board gives better density and is also cheaper. I just want to understand if density is the main requirment for sound proofing. Thanks.
Hi. I am looking for some clarification. Does acoustic insulation have different properties over thermal insulation. I’ve been told, that for soundproofing, it is all about density. If an insulation that is marketed as accoustic, weighs 10kg m3 and an insulation that is marketed as thermal, weighs 15kg m3, will the thermal insulation provide better soundproofing? Thanks.
No, those boards are not there. They've used 200mm+ screws and fixed vertical battens, through the PIR and into the rafter.
No. Im not a roofer, but have an idea of how it all works. I'm now realising that the OSB should have been laid on top of the rafters, with the VCL fitted to this.
roof tile counter batten with breather membrane between 150mm PIR insulation 8x2 rafter with mineral wool between
The ceiling is not up yet. I've spoken with a company that has advised to do the following. Fit a VCL to the underside of the rafters, board and skim, use sealed downlights and seal them to the ceiling with silicone, then use a paint on VCL to the whole ceiling before emulsion. I like the idea of the spotlight shrouds, where do you get these from? Starting to get fed up with tradesmen, just had to go around re-fiting all the door straps into the concrete infill (ICF construction), the fitter used wood screws into the foam only, an almost 1/2 tonned bifold, being held in place by bits of spray foam. Thanks for the help.
Hi. I am looking for some advice on an issue I have with my roof. The roofers have fitted a warm pitched roof and told me that the vapour barrier gets fitted on the underside of the rafters. I have vaulted ceilings on the top floor and a lot of spots and sprinkler heads. I’m now finding out that the vapour barrier should have been fitted to the boards above the rafters. Is there a way for me to fit the vapour barrier underneath, without having a lot of areas where condensation can pass through? Thanks.
Thanks for all your help. I've thought against doing all the door openings like this now. I'll just do the 2 that are needed and the rest will be standard doors. Thanks.
Thanks Mike. I didn't think about cleaning or maintanance. Maybe I will regret putiing them in.
Thanks Thorfun for the advice. I've just spoken with the chippie again and he has given me a bit more info. He said that the kits vary in thickness, but as he doesnt use the steel wrapped timber studs, he works with a 120mm thick stud wall. He rips down all the timber to 35mm on the table saw, fixes these top and bottom, which gives a 50mm void for the door. He believes that doing it this way gives a sturdier wall, compared to the kits and costs a fraction of the costs. This seems pretty straight forward for me, but I'm wondering if this wall will be sturdy enough. I may just try 1 and see, unless somebody can confirm it on here. I'm wondering why pipes, cables and sockets/switches/back boxes can't be used between the 35mm stud or is it that your kits use much thinner steel wrapped studs.
Hi. I am looking for some advice on pocket sliding doors. I am in the process of putting all the stud walls up in a new build and trying to decide on whether to use standard or sliding doors. I have 15 doors in total and the kits I’ve looked at are around £200. I don’t really won’t to pay 3k for the kits, so if this is the only option, I’ll go down the standard door route. I had a quick chat with a carpenter and he said you don’t need the kits, just good quality parts/fixings. I just want to know if these can be framed without the kit and if so, are they still quality, or is it just a bodge job. Thanks.
MVHR on new ICF build
deuce22 replied to deuce22's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Ok, so there's no comparison really. Why would the SAP company need to know, that I'm using MVHR over intermitent fans? -
Thanks both for the explanation. I have not had a blower test done, just sent drawings to the company and they've sent back a spec for it. So it's not just as simple as doubling your 160m2 house and that would almost be sufficient for my 345m2 house? How does a MVHR differ from the intermitent fans I've been told to install? -
Hi. I've been given my SAP calculations and it states that I should be using intermitent extract fans in the kitchen and bathrooms. I'll be starting on first fix shortly and so I'm going through things now. I've been told that the fans wont work properly as I dont have trickle vent in the windows, is this correct? If that is the case, the next option is MVHR. Somebody I know have just installed this in a 200m2 property and it has cost him approx £1500. My house is around 115m2 per floor over 3 floors (345m2), so I assumed it would cost me double (around 3k). I've just had a spec from bpc ventilation and the cost for the two options is between 5-5.5k. I've been told by somebody to have 1 unit for each floor as this will be more cost effective and if one fails it doesn't shut it down for the whole house. I'm looking for advice on what is the best option and what it should roughly cost per m2. Thanks.
andyscotland I'll give Celotex a call and see what they say. I've spoken with Kingspan and they said that there was no need to vent the roof with the current spec. Thanks.
PeterW Due to what has been discussed here and from my own experience I don't trust what any tradesmen say, Ive been ripped off a couple of times and also been talked into doing some things that I now realise is not the right way and has cost me more money to correct it. I will be in this property for at least 5 years, but nobody knows whats around the corner, I could be here longer. I want it to be as comfortable and as efficient as possible for whilst I'm living here, but also want to do it in the best way for anybody that buys it in the future. Is there a big benefit to having 2x 180l over 1x 300l? Iceverge ICF is 67mm in and out. I was either going to use Nudura or Jackon. The salesmen for Nudura told me that 67mm is the exact amount that is needed and any thicker is a small return on investment. Jackon ICF was 50mm inside and up to 200mm outside, when I mentioned this to Nudura they said it wasn't needed. However, Nudura has now added another system that incorporates thicker insulation on the outside, so he was obviously talking crap. I haven't even looked into air tightness. There are quite a few openings. Out of 254m2 of external walls, 64m2 are doors and windows. It is an equal L shape. ReedRichards Is the 2862 kwh, the same as 2862 units of electric?
