Rishard
Everything posted by Rishard
Also interested in this micro cement flooring. Did you go with it in the end?
Are you able to share a cost for this? Would love to know. š
It is a straight run, apart from a 45° where it joins into the stack. Iām happy to make it the designated site bog while the build progresses. That should put it through its paces. I did think about having a high level traditional cistern. Would this add any extra umphh to it? the storage solution is also a good idea. Iāve done plenty of boxes out skirtingboard plinths in the past for customers. Feels like a bit of an after thought, a cupboard sounds more intentional.
If I was to run the en-suite w/c the full distance it would need to travel 5.6m to get to the stack. Iāve got 50mm at the very most for the fall. Do you think thatās possible? Would be great if it was⦠Iāll have a building inspector but if itās the same guy, I doubt they will give it a seconds glance. More for my own piece of mind. He didnāt care a dot about the tons of mesh Il lapped to specific distances and tied beautifully all to the spec of my engineer. More interested in talking about how crap the company he works for is. Iāll try some of that banding and mating. Looks the business.
Iām going for 12.5mm per m. This works to the original plan as sadly I only have 50mm adjustment within the web of the joists. 110mm pipe inbetween the 160mm webs. Based on this lack of fall to move the en-suite w/c to the new location using the floor void to get the fall I may have to settle with its original location. Alternative option would be to exit the w/c waste out the wall and create a new stack to serve this externally on the house. Not a fan of this. or box in above floor level in the en-suite . Also not much of a fan of this. Should have gone for the larger joists⦠ah well. Maybe next time.
Ok that makes sense. I think Iāll try dog leg the stack so it comes up in the bathroom using 2 x 45° bends. Just enough offset to get through a 140mm block wall and come up on the otherside. Itās doesnāt look too upsetting. My en-suite w/c is 2.8m from the stack so I can just get the fall within my joist webs. Do you think if I wanted to move my w/c to where the basin Is in the en-suite. Could I do a stub stack in the corner where the w/c is currently located and gain the fall above floor level in boxing? Because of where the joist webs are my 110mm pipe is about 200mm from the wall. A swept bend might be needed if I was to do the stub stack option. I see in the regs that it should be avoided where possible but can be used if large radius bends or 2x45° are used. Would be using an aav.
Great. This makes much more sense than trying to run multiple individual wastes back to the stack. I want them all to be ran in the floor void to keep the rooms as clear as possible. Would I be right in thinking all these bends / connections want to be solvent welded connections?
I agree, main soil stack can be dog legged to come up in the bathroom which makes sense. Are you saying the 2 toilets should have their own 110mm run rather than joining together before joining the stack. Once the en-suite toilet waste is in the joists, is it ok to join on to this run with say the shower waste? Would I use a strap boss onto the 110 or is there a better method?
Hello, just scouring the web / forum for similar ideas relating to first floor waste runs. Iām trying to work out the best way to route my waste pipes back to my stack. Is it best to try group the en-suite shower/basin/w/c into one 110mm pipe and back to the stack, or keep w/c separate from the basin and shower? From my research, these could step up to 50mm pipe from the basin/shower and back to the stack. OR Should I be trying to group say the w/c from the en-suite and the bathroom on the same 110mm run to the stack? Keeping the en-suite basin / shower on one 50mm run and do the same for the bathroom? I have posijoists which I can route most of these runs in. The w/c near my stack could go through the wall if beneficial. Iād also take some advice on good way to fix all this pipework to the posi joists. I thought about using some rips of ply to use as a side wall which I could clip / fix pipes to (on a fall) but if there are any other good bracket fixings people have used which would take up less space Iād be interested to know. Has anyone used much dampening on the larger soil pipes to reduce noise? Just a thought as the stack is currently coming up in the corner of a bedroom. This could be adjusted to come up in the bathroom if it makes more sense. Thanks for any insights. Stack highlighted red
Aluminium Gutters / Soffits - Who to use?
Rishard replied to boxrick's topic in Roofing, Tiling & Slating
@Russell griffiths what roof system / covering is that? Looks brilliant. -
Closing cavity at the top for blown beads
Rishard replied to MortarThePoint's topic in Heat Insulation
I was aware of the fire issue in clear cavities. Itās mostly the moisture issue I was concerned with, if it is a concern at all? -
Other than preventing air movement and in some cases blown beads, is there any other reason to close of the cavity where it connects with the roof insulation? I know mineral wool is none combustible so fire spreading isnāt an issue. Is moisture travelling from the cavity wall upwards towards the roof insulation a concern at all? Iām detailing my wall junctions similar to @Mr Blobby with mineral wool. Below my rafters I will have my vcl which prevents moisture moving into the roof. I hadnāt thought about moisture moving from the cavity at eaves and the gables into the roof insulation. -
There is a ridge board above the glue lam which the rafters are all fixed to so there are no holes in the dpc. Itās also stuck down with airtightness silicone. Would have used a āsmartā membrane similar to the vcl which Iāll be using but didnāt have any to hand. Felt the dpc would be better than a roofing membrane out of the 2 available materials to hand.
Itās dpc. It will tape into my vapour control layer once the osb is attached to the ceiling. I was just going to tape the vcl to the beam but figured this would be a lot easier.
My longest ridge beam is only 6m. Iāve used glue lam throughout as I love the look of it. Iām actually lifting them up tomorrow so Iāll get some pictures. I also built a gluelam truss just to give a bit of a wow factor as itās above the main enterance at full height from ground floor to the ridge. I actually joined a couple of glue lams, they join on a masonry wall. That beam is now 10m long. My supplier could supply up to 15m I think but I would struggle to lift my beam in at 10m. My engineer calculated my beams and I basically doubled the height mainly for aesthetics. I think I could have gone deeper still. Here are a few pics:
Likewise with mine. Itās a racking layer. Not required where I am but it only cost me Ā£400 for the osb. If Iām able to osb the underside first, itāll give me a great base to snug the mineral wool into. I can then tape my vcl to it from below as itāll be a good flat surface to work with without having any bulges from the mineral wool.
@ProDave Did your frame therm come in slabs or on the roll? Did you need to make these shorter lengths to handle or could you put up large sections in one? Did it require any temporary support before you put the osb up? Good to know there is an alternative way if I decide to insulate from below. Iām also using Knauf as I find it much nicer to handle. Iām using 150mm Knauf batts in my cavity so I can also use up some of my remaining bits of insulation for between my rafters.
I would start with finding out what size your rafters need to be. Mine had been oversized by the architect to accommodate more insulation. Moving to a warm roof allowed me to reduce these and thermally break them with insulation over the top. Iād think full filling your rafter depth with a mineral or blown material will ultimately be easier to do. Mines a gable to gable with 1 small valley section. If there were dormers or hips, pir in between would become even more tricky.
@Crofter I will indeed nail up the osb first when I get a couple of clear dry days. Iāll then cut my rafter roll insulation to my rafter spacings and roll it in, followed by the pir over the top. Working from above as you say. Mineral wool still isnāt great but at least it wonāt be flapping down in my face with reduced ventilation.
Iāll chime in on this as what youāre proposing is very similar to what Iām about to undertake. Robins method requires a lot of skill and accuracy. Iāve done dozens of roofs with cut PIR between. Itās horrible. Not to mention difficult to achieve the level of accuracy. Gapo tape does help with this somewhat but comes at a very high cost. Cutting 100mm pir is hard to maintain accuracy, I have the fancy festool insulation saw and even this isnāt perfect. Iāve done 70mm sheets on my table saw where I can make repeat cuts. Doubling up sheets can help achieve your thickness. Even when every rafter is meticulously fixed and spaced there always seems to be a slither of light that gets through somewhere. If youāre prepared for cutting lots of pir and buying a boat load of gapo tape then his method is great. For me, buying Pir is by far the cheapest method of insulating sadly, combined with its uvalue itās very appealing. Using the full sheets over the top seems to be the best solution for pir, minimal cuts and thermally breaking the rafters. I have 180m2 of warm pitched roof to insulate and Iām working to a similar principle to you. It wonāt be everyoneās cup of tea but Iāve researched and costed out multiple versions of insulating this roof. Iāve had advise from my phpp designer and condensation risk calcs done. They all state the most breathable material to the outside however the VCL changes everything. Obviously it needs to be bullet proof which may be hard if your contracting this work out. For me, being the builder on this, Iām very confident I can achieve an excellent vcl in my roof build up. Height is also and issue on my project as some areas already have low eves ceilings on plan and the ridge height is already decided upon on planning. (Had I known what I know now when I put in planning 6 years agoā¦.) My build up is 120mm pir over rafters in 2 layers to stagger the joints. 145mm rafters full filled with Knauf mineral wool. 11mm osb below vcl service void. I know the risks. Iām willing to take it. The condensation risk came back ok with an effective vcl. For me, itās mainly cost and simplicity of installation that ruled. I got a uvalue of 0.1 with the above. Also have mvhr planned. I costed out dozens of alternative blown cellulose and wood fibre options. They bother required much greater rafter depths which double my timber price. Wood fibre came in at twice the price of pir for half uvalue for thickness. I know all of the above have different characteristics and achieve varying uvalues and that uvalue isnāt only thing to consider. Everyoneās circumstances are different on their project, sometimes a bit of context may help. Whoās installing the roof? Whoās installing the insulation? What do you have on your plans? What u-value do you need? Whatās your budget? If I had the money and roof height werenāt an issue I would go wood fibre over engineered rafters with blown cellulose allday.
Ok. My plans were submitted pre the last building regs change. Going from 0.13 to 0.11 ( from a quick google) In my phpp I have it at 0.104. Anywhere below 0.11 would feel satisfying. Although from some of your previous messages, the real terms difference of these uvalues may not have to drastic a cost implication from a heating perspective. I have had a quote for blown cellulose which is promising. It does come in as the most expensive option currently. Plus the additional cost of Ibeams or using local stock with extra additional timber screw on. My current favourite option is 170mm rafters 180mm mineral wool 100mm pir below rafter. Vcl 25mm service void plasterboard. All locally available and altogether come in cheaper than the supply/install of cellulose. I could take my rafters down to 145mm minimum if needed. Iāve been in circles with this, as you may see. Flipping the above option presents a ācondensation riskā in my calc. Leaving it this way does have some small thermal bridges at the ridge and the wall - roof junction where the insulation thins a little around the birds mouth connection at the wall plate. Gauging which of the 2 small compromises is better or worse is where Iām at now. No doubt there are multiple other options. Iāve priced all the cellulose/wood fibre/ mineral wool/ pir / hybrid / warm options. The more layers I add seems to add either cost and or complexity. Whatās the saying, keep it simple stupid? If only š My original architects plans are fairly lose but generally it shows 200mm pir between with 25mm under. I think we both knew at the time it wasnāt going to be this but gave us enough to put it through planning. The roof will all be hand cut with a gluelam ridge beam. All vaulted. There is some adjustment on wall plate heights if I need to favour a warm roof. And 145mm rafters would tick the box for my spans.
Also. Is the osb below the pir needed or is this for racking strength? If I wasnāt using this osb as my vcl would it need to be there? Vcl would go below mineral wool in this option.
Would an intelligent membrane work well as the vcl in option 2?
