Everything posted by Chris HB
outer hebrides it seemed like a good idea at the time…
Chris HB replied to Chris HB's topic in Introduce Yourself
Will do. I’ll be doing more pics and detail on the blog section of my site, the first piece is up if you fancy a look/read? https://www.passion4.co.uk- 56 replies
- western isles
- isle of lewis
(and 2 more)
It will be for a small domestic live work space 😎- 56 replies
- western isles
- isle of lewis
(and 2 more)
Back up again to the Isle of Lewis, this time camping in a small tent inside the building to try and stay a little warmer and more sheltered… started out a bit snowy when I first arrived, but has now risen to a balmy 8° 🤪 but hey, I finally have working electricity now! 😎 So far just removed just over a tonne of old plasterboard and disposed of it at the dump. All good progress!- 56 replies
- 6
- western isles
- isle of lewis
(and 2 more)
Condensation on solid stone walls in the Outer Hebrides
Chris HB replied to Chris HB's topic in Damp & DPCs
Since taking all the old plasterboard off the walls and ceiling, and having the windows opened a bit during the day, the wall that had the condensation on has dried out really quickly! removing the old plasterboard has helped the building begging to breathe again!- 2 replies
- solid wall
- stone wall
(and 4 more)
I’m currently stripping out the old plasterboard on my Small Mission Hall project on the Isle of Lewis in the Outer Hebrides. The building has not been in use for years and has never really had any effective heating. interesting once the plasterboard is off, you can see small drops of condensation form on the walls. I assume this is kind of normal? I’m keeping windows open whilst I work, but I assume that it will need heating at some point to help combat this? I appreciate that 500-600mm solid stone walls are likely to have moisture/damp to some degree especially being in the Outer Hebrides! In the future, I’ll need to be adding internal insulation within a standalone stud framework.
- 2 replies
- solid wall
- stone wall
(and 4 more)
external insulation External insulation on a 500mm+ solid stone wall
Chris HB replied to Chris HB's topic in Heat Insulation
I understand that it was ‘built by the community’ so yes, more utility than master craftsmen 🤣- 19 replies
- solid walls
- stone walls
(and 3 more)
There is a good local archieve, but unfortunately not much is know. They are looking into it for me though… I’ll pursue the CoS as well, but initially, they didn’t seem that interested. Intersting removing some of the plasterboard in the porch. There was a mix of some walls in stone, some in concrete block, and some a mix. Looked like some evidence of maybe some earlier/lower roof rafters? Maybe an early form of a concrete wall plate sitting above this? Feels a shame that it would need to get covered up with insulation to make it meet standards if you want to live in it! I will be doing a photo diary of sorts with it all, but electric is not connect as yet, so that may have to wait a little while. I’ll stick it on my design blog if anyones interested in following… https://www.passion4.co.uk/ Having met with a local person regarding warrant drawings etc. external insulation was not recommended. Good to hear some local expert insight. This makes the next big challenge (of many!), designing a tiny bathroom/entrance area whilst trying to navigate local accessability space allowances. I’ve been advised this is probably not possible! The ‘nuclear option’ is to convert one of the main hall windows into a front door/entrance. I’m loathed to go this route, because if you did this, you could just design and add a big side extension to the building and make everthing simple. At that point, it might as well be someone elses project…- 19 replies
- 2
- solid walls
- stone walls
(and 3 more)
I’m trying to take things slow and discover as much about the building in its as is state, just so I understand what I’ve got and where I’m starting from. Unfortunately (in some ways) the regulations will probably require me to make some fairly big changes to bring things up to current standards. I understand why this is the case, just that it might end up turning the building/project into something that I wasn’t really intending or after… 🤔 Good news is that services are all nearby so mains connections are all feasible if I want. The picture probably makes it look more remote that it actually is. Roof pitch is about 50° so with the increased height from being an old mission hall, I was planning on opening the roof space up and having a mezzanine level at one end, then keeping the other full height. The other buildings is a cool disused bus shelter with store for the funeral bier(?) behind it. People might be right about the front porch part being newer. I’ll remove some of its plasterboard and see what’s going on behind it…- 19 replies
- solid walls
- stone walls
(and 3 more)
you can get decent coffee on the island, and although I’m camping out at the moment, life’s too short for bad tea or coffee, so my AeroPress does me fine, better than most overpriced mainstream coffee chains 😉🤣- 56 replies
- western isles
- isle of lewis
(and 2 more)
thanks 😊 yeah Lewis is flatter and like a wild moorland in places, Harris and Uig are more more hilly/rocky. I know what you mean, Harris did feel kind of what I imagined the moon would be like! Absolutely loved it! 🤪- 56 replies
- western isles
- isle of lewis
(and 2 more)
yeah, I can see how that could happen. I’d potentially see this more as a base to go exploring from, rather than just a fixed permanent location.- 56 replies
- western isles
- isle of lewis
(and 2 more)
the remoteness and the raw and rugged beauty of the islands is what I loved the most! visited some stunning locations on my recent road trip from the top of Lewis down to Barra 😍 https://www.vdubxs.com/road-trips/- 56 replies
- western isles
- isle of lewis
(and 2 more)
Yep, when you only have 35 sqm to play with, every little bit really does count!- 19 replies
- solid walls
- stone walls
(and 3 more)
yep, wind is a major thing here. Apparently the regularly get winds over 100mph at least five times a year! It’s pretty exposed so wind turbines are a good idea here!- 56 replies
- western isles
- isle of lewis
(and 2 more)
There’s a tiny brook at the front, someone’s Croft at the rear. There’s mains water in the area, just trying to find the nearest access point without needing to go under the road!- 56 replies
- western isles
- isle of lewis
(and 2 more)
Yep, could well be. The longitudinal axis of the building is North/South, with the van pointing north, so the main roof you see faces West I understand that PV technology is advancing all the time in terms of efficiency, as although long hours of daylight in the summer, not always the sunniest of places! 🤣- 56 replies
- western isles
- isle of lewis
(and 2 more)
there are many classic cars (including VW Beetles and Splitties) that have had an electric conversion. The instant torque on demand must be amazing in such comparatively light vehicles compared to how much more modern cars weigh. That said, the conversion is not cheap and you can buy a lot of petrol even at todays prices for £30k+- 56 replies
- western isles
- isle of lewis
(and 2 more)
it seems to be the same thickness, so I was assuming the same construction, but I’m sure I’ll find an area where I can check… I like the idea of just a line render or earth plaster to just allow the wall breathe as that’s how the wall would become dry over time? I could live with that. I’m not sure how you’d get the U values for a stone wall or if on their own they’d meet current standards? I’d prefer to have them exposed internally, but not sure that’s a permissible option?- 19 replies
- solid walls
- stone walls
(and 3 more)
isn't that just a particular phase of a project? 🤣- 56 replies
- western isles
- isle of lewis
(and 2 more)
Thanks 👍🏼 no point in having regrets for the things you might have done, especially if you have the opportunity to give it a try! 🤪- 56 replies
- western isles
- isle of lewis
(and 2 more)
ha, to me, the T4 is new stuff! 🤣 I like old, new and future tech, and often a fusion of them all if it makes sense! I’m not personally fully convinced that electric vehicles are the way to go (but that could be a whole other topic) which is often why I like to reuse as much as possible, even in this case, with an entire building! Even if repurposing is a challenge! in many ways possibly keeping your older vehicles on the road for longer could be argued is more environmentally friendly compared to all the energy and resources required to make a new one? That said, it’s still a v1 product, so if it were me, I wouldn’t be an early adopter just yet, I’d wait and see how things develop with it. It looks interesting, needs more ideas and development with what the intended use of the rear is for IMHO?- 56 replies
- western isles
- isle of lewis
(and 2 more)
Thanks. I want to keep things fairly minimal and a little industrial aesthetic wise around the edges, possibly adding a mezzanine level in at one end, but this could be phase two of the plan! I need to find a way to make the very small lobby into a WC as well in an ideal world! Unfortunately the space for that is very tight! 🤔 Interested to hear how you approached damp with your solid walls?- 19 replies
- solid walls
- stone walls
(and 3 more)
… and the tape will self destruct in five seconds!- 19 replies
- solid walls
- stone walls
(and 3 more)
