Everything posted by Chris HB
Hi, I’m looking at getting a clean-burning 5 kw Wood/Multifuel stove as part of my Small Mission Hall renovation project in the Outer Hebrides (no, I don’t have access to a peat bank) Unfortunately, I didn’t realise just how many different options and makes of stoves that exist out there! 😳 Hoping that I might be able to get a bit of advice or recommendations as to ones that are worth looking at (or avoiding!), to try and help narrow down my search a little… Any experience or advice would be greatly appreciated!
outer hebrides it seemed like a good idea at the time…
Chris HB replied to Chris HB's topic in Introduce Yourself
OK, to make things easier if anyone is interested, you can follow progress here… https://www.smallmissionhall.com/- 56 replies
- western isles
- isle of lewis
(and 2 more)
Intumescent paint for use on OSB – who would you recommend?
Chris HB replied to Chris HB's topic in Building Materials
True, I’m just not a fan of plasterboard as a surface finish. I’m the 0.01% who wants something else 🤣 -
I will try Envirograf again, as I haven't heard back at the moment. -
Don’t suppose you still have their details to ask? 🤣 Just enquiring about 9mm Magply Euroclass A1 Non-Combustible Board 2400 x 1200mm as an option -
No joy as yet, the issue seems to be that Building standards require 30 min fire resistance, primarily because I hope to have a small mezzanine floor area for sleeping, which so far, no manufacturer can apparently meet. Struggling to find a viable alternative to plasterboard, which I would like to avoid if at all possible (single-use product, non-reusable or repurpose and you have to pay to dispose of it) -
Thanks, I’ve just got in contact with both so I’l see what they suggest? -
Hi, I’m looking into using Intumescent paint for use on OSB as an internal wall finish that needs to be fire-rated in Scotland. Can anyone recommend a supplier whose product has accredited data from an independent body such as BBA or BRE to verify that the paint product would achieve the required fire resistance on OSB sheeting?
Electric powered, Hot water-only system options?
Chris HB replied to Chris HB's topic in General Plumbing
Says 100A on the fuseboard -
Water for porridge only when I run out of milk – I'm not a fan of salt in pretty much anything, apart from Fish and Chips obvs! -
So far so good with the electricity -
That's for softies! -
Ah, is that what they are called, an unvented water heater? Helpful to know what to search for in the first instance! -
to be fair, that’s how I get washed in the morning anyway, so not a bad idea! -
up at the top near Ness – https://www.smallmissionhall.com -
One option I suppose is the stand alone hot water taps, the other maybe the small hot water units that can go under the worktop or on a wall? -
I’m after some advice or suggestions as to what to look into. I’ve been working on a small 1-bed refurbishment project in the Outer Hebrides. I have one source of energy for the building which is electricity. So for the heating aspect, I think I’ll have things covered with two stand-alone electric radiators and a wood burner. What I’m unsure of is the best option to provide hot water? Realistically I just need hot water over a kitchen sink, and in the bathroom, I was looking at an electric shower and again, a hot water tap for the basin. What would be my best options to achieve this?
Yep, got my design ideas resolved for the building, it's then getting the drawings and details for planning and warrants etc. started mid-January, hoping to get planning/warrants sorted in June/July all being well. At the moment I have a small tent set-up inside the building to camp out in, but I’m aware that when work in proper starts, the floor etc. will be coming up, and camping in the building will no longer be an option, plus I will need extra storage for the floorboards and stuff I have in the building at the moment. Luckily I have a concrete bus shelter and a store for the funeral bier that I’m trying to make usable storage spaces in the meantime.
Not sure, as technically it would not currently be classed as a dwellinghouse – part of the planning permission is to get it classed as residential in the first place, as a church meeting hall it was possibly classed as commercial (or suis generis) initially. It also means that although it is 110 years old, it gets classed as a new build as well! 🤪 Also, the ideal space for the location is to the side of the building, whereas the regs state it would have to be that it's located at the back of the house. Interesting… https://www.mygov.scot/build-shed-garage-greenhouse
Good summary! 👍 With foundations, planning permissions, warrents and then the construction itself, I think this will be way more expensive than your initial suggestion of the insulated refrigeration unit. Transportation worst case so far is going to be say £2,200, so approx £4,200 delivered. Could a metal shed with composite panels and foundations etc. compete with that cost-wise? The refrigeration unit also has the possible option of resale if I no longer want to use it as a studio space.
