  • entries
    14
  • comments
    69
  • views
    11599
Kitchen ceiling.
The kitchen has a 10.5 metre steel ridge which protrudes into the vaulted ceiling by 50cm. I also attached the ventilation 75mm pipework along the side of the steel to supply the living room at the opposite end.
So a curved ceiling to run underneath the inside of the ridge. A simple explanation is imagining a skateboard halfpipe upside down. I built a frame out of ply with cutouts for batten to run the entire length of the ceiling. I then fitted a layer of 6mm red faced ply to create a curve. Then the final layer of 4mm birch plywood, glue and pinned and treated with Osmo oil.
Well, it took a while. I know my building is not 100% square as one of the long kitchen walls was leaning out when we fitted the original rafters but overall the sheets all butted up square with only one sheet needing a little fillet added.  I started in the middle of the room to allow any discrepancies to dealt with at either end.
Then it was back to more plaster boarding and a novice bee keeper.
More to follow.
 1E749F6C-2BB6-48F3-8F87-B8D18A4F32B9_1_105_c.thumb.jpeg.34ab77fec9092a73172591dc7e0f6c99.jpeg6D5CEAAD-7831-4808-887A-871628F9A54C_1_105_c.thumb.jpeg.d5802dbcffd8c347507a64287d0df418.jpeg9A922DE5-2AD8-4A3F-8274-316990096E17_1_105_c.thumb.jpeg.00e8dc79bd868f9d53e2f9ece9cc598a.jpeg
87A684E9-7DFD-4A3C-B5C4-9B592AF75180_1_105_c.thumb.jpeg.bee1de086fba95cd4f47c9b715b90e13.jpeg
B738A605-9A14-4A16-9B4E-64198E1F3E3E_1_105_c.thumb.jpeg.fd2e97f680f44d07b3ab5673f8032613.jpegF44E4AAD-20CE-447D-940D-04DE05565B2D_1_105_c.thumb.jpeg.5d2b7312ca68bfa0d23134d5973b88c1.jpeg5CC69F53-AB1B-459F-ACB5-F66FB34D01BD_1_105_c.thumb.jpeg.c9f0bd2be463731e42d1e546dc21d6ad.jpeg
41AE577E-7282-46F2-997F-EE23962E9E08_1_105_c.thumb.jpeg.6f193d2842aab6c2e3a45dbffdb831fc.jpeg
A1099266-6BBA-4B4C-846C-31C9B1F3A086_1_105_c.thumb.jpeg.50777eda731c47becec59e43dc999644.jpeg
  • Like 13
4 Comments
Recommended Comments
PeterW
That curve is just stunning. Can’t wait to see this finished.
Nestor
Thanks Peter, I will add some better quality photos to show the the colour and grain of the birch plywood.
Gone West
Brilliant ceiling.
Tom
Agree, looks fantastic. Whereabouts in S Devon are you James? We're about to embark on a self-build in the Totnes area.
Edited by Tom
