Scaffold & Frogs
Red Kite
As per the last post - we live in interesting times and its not getting any easier! The only real upside is that the weather has improved finally. We had the scaffolders in last week and they have built round three sides to roof level and it looks HUGE as it surrounds both houses in one continuous run. It doesn't look it but it is in fact the houses will have the same  roof height as the old bungalow (fractionally lower in fact)  - we did suggest to the planners that since we have 2 and 3 story houses on either side we could come up to their ridge height with a pitched roof but they were insistent on keeping our roofs at old bungalow level - hence the flat roofs and the deep dig. We cant wait until we have the timber frames up to finally see how they look on the plot. If you look at one of the photos you can see on Plot 1 that the platform steps down which matches the split level heights of the front and back sections.
The plan is to get the Beam and Block floor in next week with a crane and then have the scaffolders back to do the front of Plot 1 and the section between the two houses in preparation (hopefully) for MBC  Timber Frame the following week. It is still very tight and could easily go off track if one of the steps fails or goes off schedule, or if the guidelines change and non-essential construction is halted. But we have our fingers crossed and are ploughing ahead as fast as is possible and safe.. From the video you can see that the guys (no gals scaffolding on this one - sorry) seem to be maintaining social distancing and its a wide open site with few people and no enclosed spaces so it seems OK from that standpoint.
We have managed to take delivery of a few key items for the preparation for MBC - our local builders merchant has been doing a great job but has decided to close as of Friday so little chance of getting anything else. This same picture seems true of the M&E (heating and ventilation) supply but Nick (from Wales) seems to have secured all we need for first fix. The thinking being that even if we get shut down then when we re-start we are all ready to move forward again as that re-start period will be total chaos as everyone tries to source materials at the same time. If you thought panic (or prudent) buying was restricted to toilet rolls .....We hear it from everyone - its a crazy world out there.
On a lighter note we decided to pump out the foundation bays which had filled with rain water to about 6 inches (they dont drain as its waterproof concrete!). We dropped the pump in and were just starting to pump when we spotted a load of frog spawn. We stopped and jumped in to collect it in a bucket to take it to a more suitable location when we discovered two (common) frogs - presumably mummy frog and daddy frog. Amazingly they had survived in what was essentially a sterile concrete pond that was impossible for them to get out of. We managed to catch them in a clean bucket and repatriated them, with their spawn to a nearby field pond. Hopefully they are enjoying their new home as ours will be covered over with a beam and block floor and be dry and very inhospitable for frogs! As they say no newts is good newts!
We have kind of lost the Week xx thread on the posts - so the latest is called Scaffold plus all the older ones can be found here :-
https://www.dropbox.com/sh/th9f6e3cel5dm1q/AAAfsWdAH184J75bCNUUtzVra?dl=0
Our internet is a bit slow at the moment so it may take a few hours (or even days!) to sync up to Dropbox so if you dont see the Scaffold time lapse video pop back in a day or so - its quite fun to see something starting to take shape above ground.
  • Like 3
1 Comment
Recommended Comments
