Protect your Fence Posts with a Postsaver
Ferdinand
A video I made whilst we were putting Postsaver protective sleeves on part of the stock of fence posts.
It is a really excellent product, which should more or less double the length of life of a fence post, and takes little more than a minute to apply once you are set up.
But make sure to buy direct from the manufacturer, because retail outlets will gouge you comparatively. The starter kits are particularly good value.
And they do trade accounts if you have a repeated need.
The feature photo repeated below shows an alternative way to  create a long-life fence - use a repair spur and keep the wood off the ground completely.
6 Comments
Recommended Comments
What life expectancy do your post come with ? I use some that come with either 15 or 20 year guarantee ( cant remember)  but a lot of the local farmers use cheeper posts that only last a max of five years.
The ones in the pic are 1.65m and 2.4m 80mm tanalised machined rounds for which I pay about £2.30 and £4.20 both inc VAT.
Normal life in my soil in my experience would be 5-7 years or perhaps a bit more, and depending on the exact environment I have reused some after that time. With a postsaver I am expecting 10-12 years, but I have not had any in the ground that long. That is more conservative than the manufacturer claims, and since Network Rail and similar are routine users I am happy to treat their claims a# credible.
Obviously it is horses for courses. For a longer life fence or a heavier load I would select a different post or perhaps go for a 100 125 or 150mm.
F
Edited by Ferdinand
I wonder how well painting a band of bitumen paint around a post would work?
Or, perhaps, painting the lower half, to just above ground level, with bitumen paint?
Interesting comment, @JSHarris.
I think a painted surface would potentially be vulnerable to the treatment / environment. EG it would suffer if knocked in to a soil with clay or pebbles with a post rammer. Treatment might also be more complex if we had to get into heated bitumen for effectiveness. But perhaps a use for eft over painted damp proof course?
That may work better if a hole Is dug first, but for me I would then probably be using a concrete post or spur plus bolted on wooden square post.
The key point is that they will rot near or just above/below the surface.
An experiment would be good, but all my current stock now have postsaver sleeves on them B|. Volunteers?
Edited by Ferdinand
I put in 150 meters of fencing and got the machined timber posts from a local N Wales supplier called Clifford Jones. The ones I bought are from their 'Platinum Plus' range and have an anticipated 25 year lifespan (with a guarantee for what its worth). The posts are kiln dried and pressure treated. They also incise the posts to get the treatment further into the wood.
Their next grade up involves sleeving the timbers similar to @Ferdinandand they quote a 35 year expected life.
