Week 15 - UFH, screed, and render base coat
As promised, I spared you a Week 14 blog due to our visit to Yorkshire for a wedding and catch-up with old friends.  It was lovely to do something unrelated to the house and it made us realise how all-consuming our build has become.  We will definitely try to have some more non-house time through the rest of the build.
That said, it’s back to the matter in hand:
UFH
Two weeks ago the guys were battling through laying the floor insulation in preparation for laying the UFH pipes, ahead of the screed pour which was booked for 3rd September.
In the end it was a very close-run thing - the UFH pipes were ready by 13:30 and the screed arrived 10 minutes later.  Too close for comfort really:  Tight project scheduling is one thing but the stress of 11 cubic metres of unusable liquid screed potentially being dumped on the site was a very uncomfortable feeling.
Screed
Once started, the screed pour itself (by Williams Walls and Floors) seemed to go very smoothly (hah!) and it looks fantastic.   We have had 65mm of Cemfloor Therm liquid screed laid.  Still in stressed-out mode I woke up before 4:00am the next day worrying about what would happen if the pipes floated up or the screed was laid too high (they didn’t; it wasn’t).  (I helpfully woke Mrs P. too just so that she could share the experience - she seemed not to appreciate it.)
We left the house shut up for 24 hours as instructed by the screed man Rob Williams.  On Friday morning I went over and opened up to find we had a sauna!  All perfectly normal apparently, but the combination of heat from the screed setting reaction, the well-insulated relatively air-tight house and (presumably) 1000’s of gallons of water created an atmosphere that made Singapore seem like a desert.
Sadly, I failed to get any photos of the clouds created as the windows were opened and the saturated ‘sauna’ atmosphere hit the September morning.   By the afternoon, with all the windows and doors open the inside of the house seemed perfectly normal again.
Seeing the screed poured in a few hours and reflecting on how fiddly all the underfloor insulation had been to lay, made me wish there was an option for a poured floor insulation - it would surely have been so much less effort and faster?
Edit: There is apparently - https://www.rtu.co.uk/assets/documents/RTU-Ultrabead-Brochure.pdf.  I have no idea if it is any good, what the pros and cons are etc, and it is too late for us but if we were doing another build (Mrs P: “We’re not!”), I’d certainly look into it.
Render
Just to make sure we weren’t missing an opportunity to get some outside work done while the focus was on the floor, we had booked our render team (Caesar Spray-rend and Plastering) to start boarding up the 50% or so of the external walls that are to be rendered (the other 50% will be vertically clad in Brimstone Ash).  So on week 14 the STS construction boards were fixed to battens and last week the base coat was sprayed and smoothed out.  It already looks a lot better just for some of the shiny breather membrane walls being covered up.  We now have to wait a week before the top coat can be applied.  We’re using EcoRend Thincoat for anyone who is interested.
And finally…
Marcus from our super groundworks team came in on Thursday to set all the stainless steel oak post brackets in concrete on top of their support pillars, and also to lay the smoothest, tidiest concrete slab you have ever seen to rest our ASHP on.
…Which is just as well because the ASHP arrives on Monday!
Dashboard:
Contractor days on site this week: 22
Contractor days on site previous week: 16
Contractor days on site since build start: 249
Budget: Getting more challenging tbh - beginning to eat into the contingency - mainly costs I hadn't properly estimated. 😱
Plan: Still on track to move in by Easter 2026.
Issues and worries closed this week:
  • UFH pipes laid.
  • Screed down!
Current top issues and worries:
  • Insulation - the additional ceiling insulation is still a worry - scheduled for w/c 15th September.
  • Like 9
18 Comments
Recommended Comments
mjc55
I'm so impressed on how efficiently things are running for you.  Of course there are always things to think (and worry) about but tbh you are making great progress.
Edited by mjc55
garrymartin
Such an inspiring blog. Look forward to reading your updates every week 🙂
G and J
"We will definitely try to have some more non-house time through the rest of the build."
Good luck with that and if you manage it let us know how....seriously going so well, and as you're a good few weeks ahead of us it's a flagging all the tidings (hopefully joyful) on their way to us.
Benpointer
Thanks for the kind words everyone - much appreciated.
I wish I knew why the random pictures appear at the end of the blog entry!
Nickfromwales
Tried moving them about on my phone. Will tidy later on the desktop 👍
Great_scot_selfbuild
Just came across this whilst browsing through the blogs - I'm planning our UFH and we'll be having a screed; what is the blue foam surround and is that part of the screeding process, or associated with laying the UFH pipes? I ask because I'm planning on laying the UFH pipes, but having someone in to do the screed.
Congrats on your build progress - looks amazing.
Nestor
junglejim
Really useful post. Thank you.
 Any chance you can share a close up of the detailing at the bottom corner of your windows externally where there will be cladding…. Just had a set back on our build… thought we were watertight but 90mph winds and torrential rain means water had found its way in at the bottom corner of windows. I thought I’d sealed/an everything well but think I had the cladding too tight to the cill so water couldn’t drain underneath. Still unsure what route it’s taken behind but interested to see how others detail this.
also… did you cut out studs in doorways? I have a sole plate with stud base plate ontop so essentially double sole plate internally. I’d like to cut out the top one in doorways so that I can run insulation and ufh and screed through easily.
 Thank you
Edited by junglejim
Benpointer
The blue foam surround is perimeter expansion strip.  The screed layers insist on it.  I assume the screed slab expands a bit when the UFH is on and this foam allows some 'give'.
https://www.theunderfloorheatingstore.com/products/prowarm-premium-8mm-underfloor-heating-edge-insulation-50m
Our UFH pipes are buried in the screed - in as much as the screed was poured over the pipes.  If you are having someone lay the UFH pipes and the screed, I expect they will fit the perimeter expansion foam but you might want to double-check.
@Benpointer thanks - I plan on laying the pipes myself and having someone lay the screed. We're on full cost-saving mode now, having had most of the build so far involve work that I simply couldn't do myself (not if I want to actually get to live in it during my lifetime).
Benpointer
 Thank you
Firstly, yes we cut out the sole plates in all the doorways.
Regarding the windows, I have trawled through our photos here's the best I can do.
First, Norrsken supplied and fitted the windows and they wrapped the breather membrane round into the reveals then filled fully the gap with sealant.  Here's a picture from the inside before they applied the sealant.
You can see the sealant here (from the outside).  I think this sealant is the key.
Ventilated cavity on the outside, sills clipped in:
Cement board:
Beading
Render + another bead of silicone
Edited by Benpointer
junglejim
Just curious how you sealed penetrations where ufh went through the stud… presumably run through a sleeve and then expanding foam?
Benpointer
Exactly so, just an offcut of waste pipe with expanding foam around.
Stoph43
@Benpointer
Your whole blog is absolutely fantastic!! We're conducting a similar build ourselves, Just at watertight stage, progress is no-where near as fast as yours but your blog is really helpful ands interesting to follow, so a huge thanks!
One question:
Can you identify what all your ducting routes were for? just to make sure I hadn't missed any in ours. Pic below for reference:
garrymartin
Benpointer on buildhub - "The ‘spaghetti’ in the bottom left corner is where all of our external service ducts come into the plant room.  17 ducts in total, including two spare at present, (I may have over-catered):
1. Power to ASHP
2. Power to garden
3. Water pipe to garden
4. Water pipe to workshop
5. Power to workshop
6. Lighting circuit - switched external lights
7. Data to workshop
8. Live power supply in (SSE - single phase)
9. Fibre in (Openreach)
10. Water mains in (Wessex Water)
11. Power to sewage treatment plant
12. PV panel in
13. PV panel in
14. Power to EV charger
15. Data for CCTV
16. Spare 50mm duct (to workshop)
17. Spare 50mm duct (to workshop)"
You might also consider control cables for the ASHP ( @Russell griffiths suggestion) and data to the EV charger if not included in the power cable make-up.
JohnMo
Depending on heat pump it could be a screened pair cable or multiple cables. And ideally doesn't want to be in power cable duct.
Benpointer
5 hours ago, Stoph43 said:
@Benpointer
One question:
Hi Stoph, thanks for your kind comments.   Our ducts were as per @garrymartin posted, although not nearly as neatly set out as yours.   I need to do an audit as we haven't used them all but I am not sure which are unused - can't get on site today or tomorrow as the access apron is being done.
