Da Bungalow
  • entries
    19
  • comments
    139
  • views
    35501
The (not so) secret diary of two self builders, one aged 62 and a half…
After what feels like forever we finally started real works.  We’ve done lots to the plot, tree clearance, root removal, digging out beds, planting, etc. but little to da bungalow itself.
We held off stripping out ‘til we were sure the project was viable, which was über cautious but that’s us.  Selection of timber frame supplier wasn’t straightforward.  It came down to a local-ish company (ETE) who supply a panelised frame for manual erection on site or stick built on site under the supervision of an SE.   Most frame companies require crane assembly, which we can’t have due to overhead wires.
But once we felt we were in the right place, planning, party wall agreements, demolition survey, site insurance, timber frame supplier, the main peeps to help us build, etc. then we got down to it.
That initially meant selling/giving away the kitchen, a fireplace, the conservatory, the UPVC windows and door, an electric fire and even a garage.
I had intended to do more stripping out before the cavalry arrived, but there was always a more important task:
digging test holes for the structural engineer (needed for the foundation design, so vital);
getting the gas meter removed/capped off and the pipe cut of at the verge annoyingly costing £1,700 (not safe to have gas on site in the way, so vital);
replacing fence panels including digging out big roots (to keep the neighbours on side, so vital);
erecting a shed, with of course a base (to keep those working on site happy, so vital);
moving the water supply (to avoid it being trashed by the groundworks, so vital);
digging in (by hand) the 10m of electric duct, casting a concrete base for and installing a huge, but apparently necessary, meter kiosk to comply with the DNO requirements, enabling them to charge us £9,500 - ouch - so vital);
dismantling the garage (which was in the way and we wanted it to be reused, so vital);
and finally, dismantling the conservatory (which was also in the way and we wanted it reused, so, you guessed it, vital).
Turns out breaking up concrete by hand is exhausting, but oddly therapeutic, even if you do bend your ancient trusty steel spade.  I wonder, have I got so used to digging foundation test holes and digging soakaway test pits and digging out roots and digging in pipes and ducts that I’m actually going to miss digging?  Scarily possible!   Who needs a mechanical digger when you’ve a mattock from Amazon and a new steel spade from Toolstation?
But then the real works start.
34 years ago we built our current house helped massively by Steve the builder, who was a bit older than us.   This time round it’s a repeat, as the same Steve is helping us and given that I’m nicely in my 60s and oddly, Steve is still older, it means that none of us are in the first flush of youth.
So my theory was that Steve was the brains and I would be the brawn.  Wrong.  Steve is both it turns out.  Monday saw us stripping off roof tiles and after a day on the battens I was wiped.  Tuesday saw me on the battens again for half a day stripping the rest of the tiles and then, just to vary things, I then spent some time on the battens stripping off the felt on one face so we could get the chimney down and kick down some ceilings (overboarded lathe and plaster).
Whilst we were out on the tiles UK Power Networks, our DNO, dug up the road and put in our underground electric feed.  And a quick bit of begging over the phone got the meter moved that afternoon, so we had site power again.  Bliss in a coffee cup.
So by the end of Tuesday I was pleased with progress but exhausted.
On Wednesday we started stripping out walls and we discovered that there was a lot more plasterboard than I first thought.  Damn.  Pronto plasterboard skip ordered, we estimated that we’d need a 4 yard skip, so to be safe a 6 yard skip was ordered.  Which meant we needed easy barrow access so we removed a window and cut a new front door.  Wednesday night I went home totally exhausted and less than pleased due to all the newly discovered plasterboard.  That night I came to terms with my limitations, so I messaged Steve to suggest he do a 4 day week to give me time to tidy up and recover.  He agreed and offered to buy me a pipe and some slippers.
(Pic of new door)
The skip arrived promptly arrived at 07:30 next morning.  There then followed a rabid day of plasterboard removal.   Incredible how effective a spade can be indoors when instructions are given to the novice. By the end of the day we’d nearly filled the skip and had just a hallway ceiling left covered in the dreaded plasterboard. I could hardly raise my arms.
One of Steve’s endearing features is his sense of humour.  One of his most irritating features is his sense of humour.  So as I’m on a step up, gritting my teeth and willing my arms up again and again yet another joke prompts the giggles.  That was it, hopeless.  My giggling got him giggling and progress paused.  Priceless.
But determination sustained and the skip was filled. Thank goodness for over-ordering.  I went home a zombie, but with less energy.
Friday and Saturday were tip runs and tidying up, and now on Sunday I sit quietly reflecting on a week that was unbelievably productive, thanks to Steve’s experience.  But oh my, it starts again tomorrow.
I have no idea if anyone will find these ramblings of interest, but they are, much like digging, remarkably therapeutic too!
  • Like 12
4 Comments
Recommended Comments
Big Jimbo
Well I just want to say.Well done. You will be fit as a fiddle by the time you get finished.
LSB
Well done Geoff, Woody won't know what's hit it 🙂
Take care
Jill & Dave
TheMitchells
Personally, i love the ramblings!  Carry on, i cant wait to hear the rest😄
Gus Potter
Plus one to that.
