Ralph Posted February 8, 2019 Share Posted February 8, 2019 Hi all, Does anyone have any thoughts on ballpark sqm cost or differences in skinning a timber frame in natural stone veneer compared to natural stone compared to fiber cement board? All would be done by a contractor. I realise this depends very much on the quality of the material but a steer would be welcome. Cheers Ralph Link to comment Share on other sites More sharing options...
vivienz Posted February 15, 2019 Share Posted February 15, 2019 I'm using tier system on my build (timber frame). This is stone veneer on a backing board, and is applied with adhesive to builder board. The builder board goes onto battens, although I need to use counterbattens as well as the centres of the battens aren't at the right spacing for the board. I sourced everything from Sydenhams after ringing around for prices; they wete by far the most competitive. The standard panels were £ 51.05 sq m, corners were the same per linear metre, the adhesive was £21.9 per bag (44 needed for mine, 126 sq m in total area excl. corners) and the builder board was £36.24 per board (sorry, can't remember the size, but same as plasterboard). Depending on which colour you want, lead times can vary enormously. Mine took nearly 2 months to arrive as it was on a slow boat from Vietnam. Link to comment Share on other sites More sharing options...
Big Neil Posted February 15, 2019 Share Posted February 15, 2019 6 minutes ago, vivienz said: sorry, can't remember the size, but same as plasterboard probably 2.4 X 1.2 then - seems the most common size. 2.88 m2 per board Link to comment Share on other sites More sharing options...
