Looking for collective wisdom on why one of our manifolds will not heat to the same temp as another.
It is usually around 5 deg C lower than the discharge temp.  I have continually tried balancing the flow but I cannot seem to get it to get any closer to the discharge temp.
Any check list or Any ideas greatfully received.
Sorry  - Yep, input - for example if the ASHP is knocking out a discharge temp of say 40degC, the manifold temperature gauge in the input pipe to the manifold will report 35degC
The other Manifold "T'd" off will be around 40degC.
Thanks
Have you considered a dodgy gauge? Measure the temperature with an external thermometer probe/laser?
Edited by AliMcLeod
1 minute ago, AliMcLeod said:
Have you considered a dodgy gauge? Measure the temperate with an external thermometer probe/laser?
Thanks, Good point - I have, I swapped over the guages from one to the other.
By touch  - it just feels cooler.
Ah, ok, I'll leave it to the experts then :)
A schematic may help. eg, if the hotter manifold is tee'd off "before" the cooler one, could there be some "backwash" from the now-circulated (and therefore cooler) water reaching the second manifold?
