lizzie Posted December 17, 2018 Posted December 17, 2018 1 hour ago, Onoff said: Can't you CT1 a wreath to a spare bit of glass and just "get a man in" every year to swap the panels over? oh if only...... 1
dpmiller Posted December 17, 2018 Posted December 17, 2018 You might laugh @lizzie but hot glue is used routinely by the guys that do paintless dent repairs on cars- search for "glue pull". The glue is easily removed afterwards with a spray of alcohol before rolling it off in one piece. No harm is done to the finish. 1
Jude1234 Posted December 21, 2018 Author Posted December 21, 2018 Thanks for the advice. I went with a Command hook upside down inside the door and a piece of string around the wreath and over the top of the door? 2
lizzie Posted December 21, 2018 Posted December 21, 2018 Well done @Jude1234 I tried all ways longest it stayed up was 5 hours. Given up now.
Ferdinand Posted December 21, 2018 Posted December 21, 2018 (edited) 1 hour ago, Jude1234 said: Thanks for the advice. I went with a Command hook upside down inside the door and a piece of string around the wreath and over the top of the door? Looks great. Here's hoping you left enough space above for the huge stretch upwards of the Marvellous Mechanical Material substrate when you take it off ! Ferdinand Edited December 21, 2018 by Ferdinand
